Sponsored by: Real Truck
Manual question
Old Mar 8, 2016 | 11:37 AM
iron butterfly's Avatar
iron butterfly
Manual question
I purchased a factory repair manual for my 2012 f350 when I purchased my truck in 2013. I tried to open it to research a P1249 code that just came up and Adobe can't open it. I have tried on two different computers. Does ford offer tech support for such problems? I could also use any info on my waste gate issue. Thanks
Old Mar 8, 2016 | 11:43 AM
Just Strokin's Avatar
Just Strokin
Have you been able to download the repair manual a second time? What is the error Adobe gives?
Try one of the links here for the P1249 code
https://www.motorcraftservice.com/FreeResources/OBD
Old Mar 8, 2016 | 01:57 PM
wrvond's Avatar
wrvond
While my copy does use Adobe in order to display information, it has it's own software that has to be installed on the computer.
Are you trying to simply access files from the file manager or through Adobe?
Take a look at the CD/DVD and see if there is an executable file you can use to install the manual to your computer.
Old Mar 8, 2016 | 10:02 PM
iron butterfly
re: manual question
Thanks for the reply and the link. I have not been able to download the repair manual. When I try to open the files I get "Adobe reader could not open ECO arc because it is not a supported file type or because the file has been damaged
Old Mar 8, 2016 | 10:12 PM
iron butterfly
re: manual question
I have not found an executable file. Perhaps I'm missing something here. Two things to add I'm using Windows 10 and as a computer operator I'm a pretty good welder. I was trying to access files using Adobe reader, do I need extra software and if so where do I get it? Thanks again for the help!
Old Mar 9, 2016 | 01:28 AM
iron butterfly
Howdy, I have successfully downloaded my service manual! And my AE scantool on Windows 10. Windows Defender has to be turned off to allow the download. Thanks for all the help! I'm still learning computers, as soon as I figure out my DTC I can cruise back into my stone aged comfort zone. Thanks again!
Old Mar 9, 2016 | 07:44 AM
wrvond's Avatar
wrvond
Good news, indeed!
peakster
Dec 5, 2014 08:00 AM
skylinetowing
Sep 16, 2012 07:10 AM
loleuiha
Feb 16, 2011 05:54 PM
Happy-Hoppie
Sep 22, 2008 09:25 PM
IDMooseMan
25
Oct 18, 2006 07:50 PM
