79 block crankshaft question
Old Mar 7, 2016 | 06:00 PM
Tuttle69's Avatar
Tuttle69
Hey guys. I've been looking and have been seeing a lot of mixed answers. I recently acquired a semi assembled D9TE block. The lower end is assembled but I am trying to figure out if the crank is external or internally balanced. There is no external weight on it now and I haven't seen one in the pile of parts that came with it. So what I've seen in the forums is that there is a casting number that indicates external in later 79 blocks and I also have seen that all 79 blocks are external. I'm trying to figure out which is true. Also is there a way to tell by looking at the crank?
Thanks, Walt
Old Mar 7, 2016 | 06:44 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
All D9TE blocks *won't* clear an internal balanced crank.
Look for 3Y stamped on the third counterweight.
Old Mar 7, 2016 | 06:48 PM
Tuttle69's Avatar
Tuttle69
Good to know. I will check that when I get home.
Now I will double check to see if that counter weight is in with the parts for sure but if it is missing do I have to have one tailored to the crank or are they all the same?
Old Mar 7, 2016 | 06:59 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Stock parts for an external balance engine are all interchangeable.
Be sure you are using a weighted flexplate as well.
Old Mar 7, 2016 | 07:02 PM
Tuttle69's Avatar
Tuttle69
Cool. Dont wanna pull the crank out to have it balanced so that's good to hear. And I will be getting the flywheel too. Thanks for the info!
Jpegg01
13
Apr 1, 2018 08:42 AM
Lead_Foot
Jul 4, 2005 02:31 PM
booneyrat75
17
May 13, 2004 09:35 AM
Superdave
Jun 2, 2003 02:07 AM
gray79f250
Sep 18, 2002 12:00 PM
