Sponsored by: Real Truck
6.0 help!!
Old Mar 7, 2016 | 07:52 AM
Jvanhalem's Avatar
Jvanhalem
6.0 help!!
Build date- 02/04...came in as no start. Would crank but not fire. Boss wanted to just throw parts at it to get it back on the road. Replaced HPOP, stand pipes and dummy plugs, oil cooler, ICP and IPR. Changed oil and all filters. Now truck will start after a bit of cranking and will run great for 30 seconds to 1 minute then it will die. When it's cranking and right before it dies it almost sounds like it's trying to hydro lock on fuel. I have another ICP and pig tail coming and I found a bad EBP pigtail so that's on its way as well. I have a torque pro app and adapter on its way in a few days to monitor everything but I could use some help sooner. I'm leaning towards injectors leaking. Please help!!!
Old Mar 7, 2016 | 08:58 AM
DJRAAL's Avatar
DJRAAL
Did you plug in the thingy to read for error codes?
If not that is where I would start!
Uppal6
Jul 15, 2015 02:18 PM
str8shot1
Mar 9, 2015 07:59 PM
zach70519
Mar 4, 2015 07:55 PM
softpickle
Jan 23, 2015 07:45 PM
dtleal
Dec 17, 2012 09:38 AM
