2005 5.4L throwing ETC codes
Old Mar 28, 2016 | 12:33 PM
rocketgirl's Avatar
rocketgirl
Update on the van. After exhausting all other options, I "drove" the van to the dealer. It was about 2.5 miles from my house and it took 45 minutes. It was epic.
Anyway, dealer says the PCM is not actuating the throttle body motor. PCM is bad. New PCM + programming at my dealer is $950. I'm looking into ordering a reman PCM and installing it myself. Dealer will program for $160.
Old Mar 28, 2016 | 02:42 PM
Tom's Avatar
Tom
Interesting. A bad PCM could cause that, but that's quite rare.
Going the reman route makes sense, but I don't think it will need to be programmed as long as you get the right code. I'd find a junkyard part if it were me.
Www.car-part.com
You can search by PCM code after you pick your model.
Old Mar 28, 2016 | 02:52 PM
rocketgirl's Avatar
rocketgirl
As far as I can tell, "programming" means assigning it a matching VIN and setting the known mileage. For this, they charge $160.
Old Mar 28, 2016 | 03:06 PM
jimbomitch's Avatar
jimbomitch
Do a web search for: spareecm or look for their store on eBay, they'll sell you one already programmed.
Old Mar 28, 2016 | 03:28 PM
Tom's Avatar
Tom
I don't have any information on this specific vehicle, but I'd double check that. Most models I'm aware of have the anti-theft and mileage stored in the instrument cluster.
Different generation, but I replaced the PCM in a '97 Lincoln Town Car and no programming was required. There were like 6 different codes for that model year, and they weren't interchangeable without reprogramming. I found one of the proper code about 40 miles away and it worked great.
Old Apr 29, 2016 | 10:18 AM
rocketgirl's Avatar
rocketgirl
Final update on the van. I went with a re-manufactured PCM from NAPA. It took the dealer three attempts to reprogram it. I couldn't get a clear answer on why exactly it took three tries. Anyway its been about a month since we got it back and everything seems fine now.
Thanks for all the feedback here.
Old Apr 29, 2016 | 10:26 AM
Tom's Avatar
Tom
Glad to hear you got it figured out! PCM failures aren't common, but they happen. Often people jump to replace the PCM and get frustrated when it doesn't fix their issue. Glad it worked for you.
blacklab5
Aug 4, 2017 04:09 PM
AGrayson84
Nov 4, 2016 01:57 PM
Justin Marnoch
Dec 16, 2015 07:07 PM
sexwax
2004 - 2008 F150
Mar 17, 2010 11:15 PM
fordtrucksj
Bronco II
Oct 19, 2008 11:46 PM
