I have codes now
Old Mar 9, 2010 | 09:09 AM
sexwax's Avatar
sexwax
I have codes now
I have a question. My 2006 F-150 super crew 5.4 has a issue. I can be driving down the road and then the truck goes to idle and no control with the gas peddel. I get a engine light as well as a wrench. If I shut the truck all the way off I can restart it sometimes one try sometimes more. Not good in traffic. this has happend 20-30 times and I have changed the TPS with no change. Anyone know what to do???
2 of the codes I got are
P2104- TAC system forced idle
P2112- TAC system stuck closed
Changing the TPS did not seem to fix this issue could it be the ECM?
Old Mar 11, 2010 | 05:49 AM
sexwax's Avatar
sexwax
Anyone have a answer for this?
Old Mar 11, 2010 | 06:56 AM
shorebird's Avatar
shorebird
Repair or replace the throttle body.
You write; "2 of the codes I got are"; Did you get any other codes?
Old Mar 11, 2010 | 11:14 AM
sexwax's Avatar
sexwax
No I only had 2 codes but the check engine light did not stay on this time. How do you fix a throttle body? There is not much to them on the ford.
Old Mar 15, 2010 | 11:36 AM
sexwax's Avatar
sexwax
Out of all these people on here I can not get my question answered
Old Mar 15, 2010 | 06:05 PM
bridge's Avatar
bridge
Sick 'n Tired
Most likely not the PCM if there are not other codes. Like shorebird said...replace the TB.
Old Mar 17, 2010 | 06:16 AM
sexwax's Avatar
sexwax
Ok it happend again this time I got one extra code then before and code P2104 showed up twice but the truck only dropped to idle once.
3 of the codes I got are
P2104- TAC system forced idle (2 times)
P2111- TAC system stuck open
Will this extra code help with finding out whats wrong?
Old Mar 17, 2010 | 07:15 AM
shorebird's Avatar
shorebird
It is of no extra help than before it showed.
The TAC ( throttle actuator control, IE; throttle body ) is malfunctioning.
Get it fixed ( cleaned ) or
Replace the throttle body.
You have the solution in front of you.
Old Mar 17, 2010 | 09:06 AM
sexwax's Avatar
sexwax
Shorebird should I clean it with carb cleaner or is there something better? I will try and clean it before I buy a new one. Do you have an idea if I need to buy a new one where would be a good place?
Old Mar 17, 2010 | 09:39 AM
double06's Avatar
double06
https://www.ford-trucks.com/forums/9...placement.html
Some more info for you.
Old Mar 17, 2010 | 12:03 PM
sexwax's Avatar
sexwax
Thank you Double06 that info helped out quite a bit. I will be taking care of the TB this weekend.
Old Mar 17, 2010 | 10:56 PM
SMok's Avatar
SMok
Old Mar 17, 2010 | 11:15 PM
markhf's Avatar
markhf
I have a 1994 F150 on the left side of the stearing wheel on the dash I have a engine light that blinks 3 times and then 2 times is this a coad. and if it is what dose it mean. I have poor gas mileage. their is 200000.0 miles on it runs good.how do I clear it out.can aneybody help out. Thanks
1979 300i6
16
Feb 7, 2016 12:16 PM
Iron782
Aug 15, 2013 10:32 PM
LACityFD
2004 - 2008 F150
Jun 19, 2009 03:44 PM
