Sponsored by: Real Truck
Forced Idle. Please Help.
Old Jun 19, 2017 | 04:17 PM
blacklab5's Avatar
blacklab5
Exclamation Forced Idle. Please Help.
I have a 2005 F250 5.4L 2wd. Parked the vehicle in my driveway and the next morning there was no response from the accelerator and the CEL light and the wrench light on. I pulled the codes and came up with codes P2104, P2107 and P2110. The KOEO code was P2122. I checked the wiring and connectors and all appear to be fine I replaced the throttle body and no change. I removed the accelerator pedal and tried it on another vehicle and it worked fine. I have power to pin 16 on the diagnostic port. After clearing the codes and rescanning the same codes come up immediately. I would appreciate any help diagnosing this and thank you in advance.
Old Jun 20, 2017 | 01:31 PM
blacklab5's Avatar
blacklab5
Any advice would be helpful and appreciated.
Old Jun 20, 2017 | 06:28 PM
adman02's Avatar
adman02
Not sure how much of this applies to your vehicle, but googling those codes led me to this: https://www.ford-trucks.com/forums/6...s-related.html. Post #14 looks promising.
Old Jun 20, 2017 | 06:31 PM
adman02's Avatar
adman02
This video suggests maybe shorted wires
Old Jun 20, 2017 | 07:16 PM
blacklab5's Avatar
blacklab5
I saw that one. I will check the the harness again. Similar situation. Thanks
Old Jun 21, 2017 | 01:44 PM
Mike1's Avatar
Mike1
You pulled 4 codes 3 of them closely related to each other , the 4th one P2122 is the gas pedal position sensor it relies on 2 signals, if signal1 is outside it's parameters, it sees fail and the rest of the codes are set that you are seeing. Did you also check your TPS? also make sure that nothing physical has gotten into the way of the TB linkage, holding it open a little bit. Also check to make sure your throttle control motor is operating and as said before, recheck your wiring harness.
Old Jun 21, 2017 | 01:53 PM
blacklab5's Avatar
blacklab5
I replaced the throttle body assembly and tried the pedal on another vehicle. It worked fine. Harness looks good and when I start the engine it idles up to 2000 rpms and comes down. When idle comes down it seems to have a misfire. What other issues would cause forced idle mode with those codes?
Old Jun 22, 2017 | 06:32 AM
The Bone's Avatar
The Bone
Sounds like a throttle position sensor may be bad. May be something better fixed at the dealer. You could throw more parts at it and never solve the problem. How much did the throttle body cost?
Old Jun 22, 2017 | 06:36 AM
blacklab5's Avatar
blacklab5
185.00 with TPS.
Old Jun 22, 2017 | 07:44 AM
Mike1's Avatar
Mike1
Did you check voltage on the sensor wires? I know you said you checked power to pin 16 but did you check to see if you have too low of a voltage? With everything you've already replaced, I think it's time to run the voltage draw and check all your grounds.
Old Jun 22, 2017 | 09:01 AM
blacklab5's Avatar
blacklab5
Voltage was 12.9 at pin 16. I will check the other connections today. Thanks
Old Jun 28, 2017 | 08:54 AM
blacklab5's Avatar
blacklab5
I checked all the wiring for the TPS and all is good. Does the PCM need to be reflashed with the replacement of the throttle body? Old throttle body had old style TPS.
Old Jun 28, 2017 | 10:20 AM
Mike1's Avatar
Mike1
According to what I have read, that if you have validated the wiring, connections, voltages and sensors are where they're supposed to be then more than likely your PCM needs to be replaced, BUT, you said " Old throttle body had old style TPS" I didn't know they changed the TPS so maybe a reflash would do the trick, although I wouldn't think the TPS change would mean you'd have to reflash the PCM because that means the everyone that had to change it would need to go to the dealer and pay for a reflash.
Did you pull the connector at the PCM and check the pins for corrosion or any pins pushed back or bent?
Old Jun 28, 2017 | 10:58 AM
blacklab5's Avatar
blacklab5
Yes I did.
Old Jun 29, 2017 | 10:34 AM
blacklab5's Avatar
blacklab5
Still getting P2104, P2107 and P2110. KOEO I get P0121 P2110, P1397, P2107,P2104. Driving me crazy!
