Engine serial numbers
Old Mar 6, 2016 | 09:06 PM
444dieselrod's Avatar
444dieselrod
Anyone have the breakdown of what numbers are what years??
Old Mar 6, 2016 | 09:56 PM
fordpride's Avatar
fordpride
94.5-95 engine serial no. 201680 & before)
96 and up engine serial no. 201681 & up
Old Mar 6, 2016 | 10:02 PM
fordpride's Avatar
fordpride
Start of production thru 1425746 are Forged Rods
1425747 thru 1440712 are Powdered Rods
1440713 thru 1498318 are Forged Rods
1498319 thru final production run are all powdered
Old Mar 7, 2016 | 11:27 AM
444dieselrod
Is that also the break for the front cover change? I've got a couple motors sitting here that I don't know the history.
Also one is a Ford reman and they punched over the serial number with 0's....I am assuming the 178974 is the number???
Old Mar 7, 2016 | 11:33 AM
444dieselrod
Old Mar 7, 2016 | 11:49 AM
fordpride's Avatar
fordpride
Yes and yes.
My first post is the obs serial #'s and my second post is the start of the sd engine e99-03 7.3L
Old Mar 7, 2016 | 11:51 AM
fordpride's Avatar
fordpride
And to be honest the only true way to tell if the sd engines are forged or pmr is to pull the inspection plate on the side of the block.
Old Mar 7, 2016 | 11:54 AM
444dieselrod
I know both mine are OBS motors, was just wondering if they were pre 95's or not as both are missing the tag on the HPOP res.
Thanks for the help.
Old Mar 7, 2016 | 08:14 PM
BBuford1962's Avatar
BBuford1962
I have to show my ignorance here. What's the difference in forged and powdered rods?
Old Mar 7, 2016 | 09:23 PM
fordpride's Avatar
fordpride
Forged is one continuous piece of metal.
Pmr =Power Metal Rod is basically a bunch metal shavings pressed together kinda like MDF or OSB strand board
Old Mar 7, 2016 | 09:36 PM
BBuford1962
YUCK!...I'd hope my '96 has forged rods....
Old Mar 7, 2016 | 09:47 PM
fordpride's Avatar
fordpride
You do. Pmr started in 01
Old Mar 8, 2016 | 08:49 AM
BBuford1962
gfoster
Aug 3, 2008 10:34 AM
stonie
May 8, 2006 06:29 PM
herb og
Oct 5, 2004 05:46 PM
1970explorer
May 27, 2003 10:31 PM
