Sensor Cleaning
Old Mar 6, 2016 | 08:39 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Sensor Cleaning
Stupid question time
Just want to get it all in one place for posterity and all
Cleaning sensors:
EBP: Remove sensor and remove carbon carefully with string trimmer line or straight pick (don't puncture diaphragm). Remove tube, spray with carb cleaner, and "rod" out with string trimmer line.
MAP: replace hose. Clean sensor carefully with something soft, q tip and no chemicals?
MAF/IAT2: spray with MAF cleaner. follow instructions on can, maybe clean element with 90% isoporpyl alcohol on a q-tip carefully
BARO: leave it alone?
IAT: spray it with MAF cleaner. typically replace if it's really causing issues?
ECT/EOT: spray with alcohol to remove oil. swap or replace as needed
Cam/Crank: replace
ICP: replace
Old Mar 6, 2016 | 10:45 PM
mhoefer's Avatar
mhoefer
Other than Cam and Crank sensor or ICP, which I have no experience, sounds right to me. I have done sensor cleaning several times when problem solving a bad EGR. One thing I would worry about is your pick comment, on the EBP, I would not pick at it at all, only rinse with MAF cleaner and let air dry, it takes more shots of cleaner but it does come off and come clean, at first it just looks like it won't ever come clean. I have cleaned mine twice and it's still working. For what that's worth.
Old Mar 7, 2016 | 08:42 PM
billbot's Avatar
billbot
Thanks man! Just getting ready to clean mine this week.
Old Mar 7, 2016 | 09:25 PM
04badford's Avatar
04badford
The only two sensors I will spray at is IAT2 and MAF , maf only spray and the consciences states brake cleaner , but I have always used Carb cleaner and a plumbers flux brush .
Oh and ware your safety glasses that stuff burns like
Old Mar 7, 2016 | 09:43 PM
silverbullet6oh's Avatar
silverbullet6oh
I only use carb cleaner as I figure it is actually made to be used in conjuction with engine parts.
Old Mar 7, 2016 | 09:54 PM
04badford's Avatar
04badford
Carb cleaner is harsh on some things but not as harsh er as brake cleaner , don't know silver kind of what I was thinking aswell
Shogun6
Modular V10 (6.8l)
Apr 3, 2012 10:23 AM
mdpitt
1997 - 2003 F150
Sep 11, 2007 09:56 AM
fderflinger
Aug 21, 2007 06:38 AM
superduty lee
Modular V10 (6.8l)
18
Jun 4, 2007 07:08 PM
el conquistador
1983 - 2012 Ranger & B-Series
Feb 10, 2004 10:06 PM
