differential
Old Mar 2, 2016 | 11:58 PM
michael willis's Avatar
michael willis
differential
I have a 1994 ford f150 xlt 5.0/302. I am having touble finding out the front and rear axle sizes so i can get the right gear oil weight. I know the rear is a 8.8 ratio. But dont know the front yet. How do i get the info
Old Mar 3, 2016 | 09:39 AM
exranger06's Avatar
exranger06
The rear is not an "8.8 ratio." It's an 8.8 axle. The 8.8 refers to the diameter of the ring gear. The gear ratio has nothing to do with it.
The front is a Dana 44 twin traction beam (TTB) axle. That's the axle that EVERY 4x4 F150 from that year had.
The correct gear oil is any 90 weight, such as 80w-90 or 75w-90. As long as the second number is 90, it'll work. Conventional or synthetic, whichever you prefer.
Old Mar 3, 2016 | 01:55 PM
madpogue's Avatar
madpogue
^^^^ That would make for one slow truck....
Old Mar 3, 2016 | 03:28 PM
Freightrain's Avatar
Freightrain
The door tag should have the code for what the ratio is suppose to be(if no one changed it). If not, you can look for the tag on the one of the bolts for the cover. It will tell you.
8086ford
Feb 17, 2016 12:13 PM
DungeonCustoms
1997 - 2003 F150
Jul 12, 2006 03:46 PM
caswensk
1997 - 2003 F150
Apr 30, 2005 06:36 PM
1986 truck and driver
Aug 27, 2003 08:56 PM
rabidranger
Apr 21, 2002 06:31 PM
