Sponsored by: Auxito
8.8, 9.75, or 10.25 Rear diff?
Old Apr 30, 2005 | 08:24 AM
caswensk's Avatar
caswensk
What's the easiest way to determine which rear differential my 2001 Supercrew has? Bought it used and I guess I never looked into it. The qty of friction modifier changes from 4oz to 8oz depending on the size....
Old Apr 30, 2005 | 11:28 AM
sbeII's Avatar
sbeII
There should be two metal tags attached to the axle cover bolts on the rear of the axle. One of those tags will have a plant code (usualy starting with a v or a s)that tells you which plant it came out of, a four or five digit number[year(#)|month(letter)|day(#)], a 3 didgit number(axle ratio)[example 3 .08 or 3 .55], and a ring gear diameter # which will be two digits(for example 8.8). If your looking at the right tag, the axle ratio will be on the bottom left of the tag, and dirrectely to the right of that will be the size.
Most axles are like this and if yours isnt let me know and i can find out how to identify it.
John
99 f-150 4x4 ext. cab(84k)
rear steel buper..grilleguard w/4 KC lights
tool box..bed linner
dual exaust..K&N air intake...<!-- / message --><!-- / message --><!-- / message --><!-- / message --><!-- / message -->
Old Apr 30, 2005 | 11:30 AM
sbeII's Avatar
sbeII
Another option is to just to buy Royal Purple Gear lube which already comes with the additive in the oil.
Just an option.
John
Old Apr 30, 2005 | 02:02 PM
caswensk's Avatar
caswensk
My tag reads exactly:
3 S 941 A
55 9 75 OK31
I assume the 9 75 means the 9.75 inch rear-end...
Yes/no?
Old Apr 30, 2005 | 06:36 PM
jcstratt's Avatar
jcstratt
there is another number and maybe letter under the bolt head. The short answer is yes, you have a 9.75 (you probably also have a 5.4L engine). The number and possible letter that is under the bolt head should be a 3. So if it reads 3 55 9 75 OK31, then you have a 3.55 gear and a 9.75 open rear end. if its 3L55 9 75 OK31, then you have a 3.55 gear and a 9.75 limited slip rear end. Also, you can look at the sticker on the driver's door jamb and get the axle code. You can figure out what it means here https://www.ford-trucks.com/article/...r_Decoder.html
issyrog
6.4L Power Stroke Diesel
Nov 7, 2014 07:52 PM
myoldvan
Jul 19, 2013 04:20 PM
sarnott140
Mar 17, 2012 07:09 PM
Robby Nash
Mar 11, 2012 03:11 PM
Rob88
Mar 28, 2000 11:15 AM
