Old Gas Treatment
Old Gas Treatment
Alright. I got a 1990 F150 straight six that has two fuel tanks. The front tank I have been using since I have gotten the truck back in December. Before it came into my name it sat in the driveway since near the end of 2012. I switched the fuel gauge to the rear tank and it says the tank has half a tank of fuel left. Considering that I'm not able to drop the tank to remove all the old fuel. What should go about doing? Add some kind of fuel additive to it and fill with fresh gas?
I can't remember who makes it (Stabil, perhaps?) but there's a product to 'rejuve' old gas. Most marine shops or perhaps even Walmart sell this. You don't seem that bad off as you have only 1/2 tank. I'd use this, along with fresh gas & burn it up as fast as you can. Run it to near empty then re-fill with fresh fuel. You should be fine!
Well... I do have a disconnect tool for the fuel filter since I haven't gotten around to replacing it with the one I bought since I been busy. All I would need to do relieve the pressure and then find a place to put all the old fuel. The rear tank is 16 gallons. Which if the gauge is reading right it has around 8 gallons in it.
Get a long siphon hose and pull a sample from the bottom of the tank and see what you think. Is it cloudy or yellowed, oxidized, tar *****, stinky like paint? Or sparkly clean and smells fresh gas?
"stabil" and other fuel stabilizers work when you add it BEFORE putting a machine into storage ... although i doubt they would work for 3 1/2 years. there is no additive that i know of that will rejuvenate old gas after the fact; so don't waste your time/money. nor is it a good idea to add fresh gas to the half-tank of stale gas. in the old days, you might have gotten away with it, but as previously stated, gas doesn't keep well nowadays, and 3 1/2 years is waaaaaay too long to have any hope.
KevinE350
01-11-2011 06:24 AM
rx3greenford
09-06-2002 02:03 AM
