Battery location
Old Mar 1, 2016 | 09:07 AM
schoo's Avatar
schoo
Battery location
I needing some ideas for the battery I tried to fit in the next to the engine and fab up a tray but not much room for spark plug removals no room under the cab
what about in the cab do you guys have any pic
Old Mar 1, 2016 | 12:14 PM
eman92082's Avatar
eman92082
I mounted Optima 6 Volts on each side of the vehicle outside the frame just behind the cab. I modified Optima 6V sized brackets from Speedway. They are connected in series with 1/0 cable with a master shut off in the cab and power terminals on the firewall.
Pricey, but the set-up works great and the batteries last years between replacement.
Old Mar 1, 2016 | 12:40 PM
schoo's Avatar
schoo
thanks Ernie
Old Mar 1, 2016 | 12:43 PM
Don Vito's Avatar
Don Vito
I used a frame mounted drop down battery box from CPP. Easy install and looks good. (polished stainless)
Don
Old Mar 1, 2016 | 12:48 PM
schoo's Avatar
schoo
thanks don
mustangmike6996
Jul 26, 2015 12:34 PM
7636074460
Dec 12, 2012 01:04 AM
seanmconroy
16
Mar 26, 2011 05:43 PM
B/B ford
Mar 10, 2006 12:28 PM
johnnynegaunee
Dec 22, 2005 03:31 PM
