Dana 44
Old Mar 1, 2016 | 08:00 AM
Creamsicle88's Avatar
Creamsicle88
Dana 44
Hi I'm looking at buying a Dana 44 HD with disc brake and is the high pinion axle. It need the inner and outer shaft on the driver's side and I have a Dana 44 low pinion with drums in the front and I was wondering if I could just swap the axles from mine into this one
Old Mar 1, 2016 | 08:54 AM
twinzilla's Avatar
twinzilla
First off I don't believe the high pinion 44's were referred to as 44HD's. The 44HD's were the low pinion axles that came in highboy's with the large external locking hubs.
And no, I don't think you can swap axle shafts between an open knuckle & closed knuckle Dana 44.
Old Mar 1, 2016 | 09:10 AM
Creamsicle88
Okay thanks,
Old Mar 1, 2016 | 09:16 AM
ZarK-eh's Avatar
ZarK-eh
Some '77 F-250's had HD High Pinion Dana44 Axles.
It's a little wider than my F150 Dana 44 so the shafts don't swap. But the steering knuckles out to the hubs swap over.
Old Mar 1, 2016 | 09:20 AM
Creamsicle88
Thanks do to the brackets for the leafs line up still? I have a f250 highboy with the old low pinion d44 in it so I'm hoping they do to the newer 77 high pinion d44
Old Mar 1, 2016 | 10:53 AM
twinzilla's Avatar
twinzilla
I don't think they were called a 44HD though were they? They're just your standard high pinion Dana 44 just like the 78/9's. 77.5's were not "highboy's".
Yes, the spring perches should be the same distance apart on the high pinion 44 if it came out of a 77.5-79 F250.
Old Mar 1, 2016 | 03:18 PM
buckin69bronco's Avatar
buckin69bronco
I may be wrong but I've always heard of the late 70's F250 Dana 44 being refered to as the 44HD. Being that it has 8 lug hubs and bigger brakes and is suppose to have 3" tubes with 1/2" think walls.
Old Mar 1, 2016 | 05:06 PM
mark a.'s Avatar
mark a.
I'd find a high pinion axle and swap the whole thing in. You would need the prop block, power brake booster and master but all in all it would be a great upgrade for the truck. Your drive shaft angle will be a lot better too.
hail destroyer
18
Oct 13, 2025 08:50 AM
Creamsicle88
Mar 3, 2016 06:35 PM
twinzilla
Jul 11, 2015 06:24 AM
302flareside1992
Jun 11, 2011 12:05 AM
holl
1966 - 1977 Early Broncos
Feb 19, 2002 09:36 AM
