Motor Mount Question
Old Feb 29, 2016 | 05:53 PM
Riskit's Avatar
Riskit
Hello, I have a 73 F250 2wd and I'm swapping out the motor for a 63 FE stroker I'm building. I'm told the 73 has a 3-bolt motor mount set-up and the 63 has 2 bolts. Is the work around hard? Anything I should be carful of. The stroker is gonna be built a bit and i see a small shot added so should I be nervous about anything. Every time I mention the swap the first think I hear is about the blocks and bolts being different. Thought I'd ask
Thanks
Old Mar 2, 2016 | 06:20 PM
Riskit's Avatar
Riskit
Nothing? BUMP
Old Mar 2, 2016 | 07:59 PM
lpdcjr's Avatar
lpdcjr
Originally Posted by Riskit
Nothing? BUMP
Either drill your motor mounts to fit the block, or try a set of early mounts for a 352 truck.
crazy96863
Jan 24, 2013 10:29 PM
whiteisright
Oct 16, 2011 01:57 PM
Mike G
Jul 16, 2010 09:52 AM
Phillip Guidry
Oct 24, 1999 03:19 PM
