A quick FE motor mount question
Old Jul 8, 2010 | 11:25 PM
Mike G's Avatar
Mike G
Can someone please refresh my memory as to the orientation of the motor mounts on a 65 FE. Are the two block bolts on the front/leading edge of the single perch bolt (ie placing the motor forward) or is the perch bolt found first, placing the motor back?
Thanks gang, --Mike
Old Jul 14, 2010 | 06:08 PM
OldHarley's Avatar
OldHarley
I have looked on my '66 F100 with a 352. But, I am not sure I understand your question.
There are two bolts into the block (one above the other) that attach each motor mount. I think there is only one way they can go. The single perch motor mount bolt goes thru the middle of the mount and bolts to the middle of the perch.
Now, this is a guess, there are some additional holes in the frame adjacent to the perch that I suppose could be confusing you and look like the motor location could be shifted forward/back. If those are the ones in question, then leave the front holes unused. That effectively would make the engine mounted closer toward firewall.
OR, if you could clear up what you are looking for, it might help with an answer.
Old Jul 14, 2010 | 11:07 PM
Mike G's Avatar
Mike G
Thank you for checking. The two bolts that go through the mount and into the block. Are they in line ahead of the single post that goes through the perch (mounting the motor back), or are they behind it, mounting the motor forward.
Old Jul 14, 2010 | 11:31 PM
tbm3fan's Avatar
tbm3fan
Now I understand what you are asking. I'd have to say that the bolt through the center of the perch is just slightly ahead of the two into the block.
Old Jul 16, 2010 | 09:52 AM
Mike G's Avatar
Mike G
Nice, a picture is worth a 1k words... Thanks guys!
--MG
bsiebert
Jun 18, 2016 12:27 PM
roadrash63
Dec 29, 2015 01:58 PM
bsiebert
18
Jun 23, 2011 05:35 PM
havi
Engine Swaps
28
Apr 18, 2011 02:15 PM
HIO Silver
Jun 12, 2010 11:48 PM
