Crank, No Start No Codes
Old Feb 29, 2016 | 05:46 PM
mtnxtreme's Avatar
mtnxtreme
Truck ran good, but for the past month every once in awhile it would just stall quick, no rumbling, no smoke, like someone just turned off the ignition, if you turn the key it would immediately fire right back up. Well today it would not start back up. Pulled the IPR plug, no good. FICM replaced abt. a month ago. Checked with Scan Gauge, oil pressure abt. 925 while cranking dropped to abt. 780 after extended crank. And no codes. I do notice when turning key on I hear less clicking/noises going on. All dash lights come on and turn off as usual. Tach doesn't move. Hope this helps, any ideas ?
Old Feb 29, 2016 | 08:25 PM
BLADE35's Avatar
BLADE35
You supposed to pull ICP
Maybe that's what you did worded it wrong I assume
Don't sound like PCM is losing power since you don't mention a gauge sweep
But that's not you problem sounds like a shorted wire or bad ign switch
Old Feb 29, 2016 | 08:45 PM
mtnxtreme's Avatar
mtnxtreme
Blade I was hoping you'd be around. Yes ICP plug in passenger valve cover. Also a sensor below the fuel filter, I pulled that too because I wasn't sure which one it was, been a few years since I played with a 6.0, went 6.7 but just picked this 6.0 truck up for snow plowing. No gauge sweep, dash acts normal. So where next ?
Old Mar 1, 2016 | 01:58 AM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
Even though your FICM was replaced recently, have you checked its output voltage?
Old Mar 1, 2016 | 02:13 AM
mmsllc's Avatar
mmsllc
48 volts at the FICM is the very minimal. Anything less is considered LOW!! I'm thinking it is a bad IPR, or HPOP. Also try unplugging your fan clutch. It is rare, but if it goes bad, it CAN keep the engine from starting. Luckily, it is very easy to un-plug.
Old Mar 1, 2016 | 05:55 AM
WatsonR's Avatar
WatsonR
check crank/cam sync on your scan gauge
925 is enough pressure to start and run
Old Mar 1, 2016 | 07:17 AM
Rusty Axlerod's Avatar
Rusty Axlerod
48v is designed output, less than 45v is time for repair. It's common to see a perfectly functional FICM flip back and fourth from 47.5 to 48. Output should be checked under all driving conditions but common times for the voltage to sag are KOEO, during cranking, at cold idle, and under load.
Old Mar 1, 2016 | 07:53 AM
mtnxtreme's Avatar
mtnxtreme
Its funny you guys are saying this, because after a cold soak this morning I said maybe I should check the FICM, KO 20, key on for abt. 30 seconds ZERO , and the other reading was 8.0, then after 30 seconds .20, ugh its like a month old !! And my batteries are good, 13 volts KO.
Old Mar 1, 2016 | 08:16 AM
Rusty Axlerod
"Other" reading was FVP? FLP? Maybe the relay is crapping out on you.
Old Mar 1, 2016 | 12:00 PM
mtnxtreme's Avatar
mtnxtreme
OK I just went to check on it again FVP 13.0, FLP 6.50, FMP 30.5, if I leave the key on for abt. 30 seconds the FLP slowly drops to .20 and the FMP slowly goes to zero . FVP stays the same.
Old Mar 1, 2016 | 12:38 PM
WatsonR's Avatar
WatsonR
stick a fork in it.... or butter it if you prefer, its toast! I'd be checking your batteries and alternator, they are not helping.
Old Mar 1, 2016 | 02:04 PM
mtnxtreme's Avatar
mtnxtreme
What Relay Rusty ?
Old Mar 1, 2016 | 02:06 PM
mtnxtreme's Avatar
mtnxtreme
Batteries and alternator are good ! I think maybe I just got a bad FICM rebuild from FICM Ron. On a good note it's warranteed for a year.
Old Mar 1, 2016 | 02:16 PM
WatsonR's Avatar
WatsonR
FICM relay, under the hood drivers side.
Old Mar 1, 2016 | 02:30 PM
mtnxtreme's Avatar
mtnxtreme
OK I'll throw a fresh one in and see if it starts, if it does, should the FICM be ok ?
