AC probkem
Old Feb 29, 2016 | 01:36 PM
tbax46's Avatar
tbax46
AC probkem
Compressor continually clicks off and on.....no cold air....checked freon seems to be full.... Big line never gets cold....any hints
Old Feb 29, 2016 | 01:49 PM
WatsonR's Avatar
WatsonR
that's usually the sign of low freon, on-off-on-off. You sure its full enough? ambient temps also influence amount of charge.
Old Feb 29, 2016 | 01:55 PM
whomrig's Avatar
whomrig
yes this is a sign of low refrigerant. do you have gauges to use? also, on my 2000 when the a/c is on max, the vent temp is 38deg, this was at the last service with a new compressor and receiver/dryer. have you looked under your rig to see any drips on the bottom of the a/c compressor?
Old Feb 29, 2016 | 04:15 PM
tbax46's Avatar
tbax46
No drips ...only gauge us the little on one of those refill cans
Old Feb 29, 2016 | 09:31 PM
whomrig's Avatar
whomrig
the a/c compressor may be ok the system needs to be charged to really know what you have.
did you hook up your gauges yet?
Old Feb 29, 2016 | 09:55 PM
jetjockey99's Avatar
jetjockey99
The little gauge on the can is a nice sales gimmick, but not very accurate. You need real gauges to diagnose. And yes it sounds like you have low refrigerant levels.
Old Mar 1, 2016 | 02:08 AM
mmsllc's Avatar
mmsllc
Get & hook up a real set of gauges. After all, you are probably going to save enough money by not having to go to a mechanic. They run around $65. When it clicks on & off rapidly, it is a clear sign that the ac system is LOW on FREON charge.
The exact symptom that you have described is a text book ASE question for becoming ac repair certified.
Another good tip is: your high side pressure should read close to 2.5 times higher than the outside air temperature you are working in. Another tip: turn your truck on, is there LOT of air flow behind the radiator fan? If not , it is time for a new FAN CLUTCH. Replace it ASAP, or far more expensive repairs will be soon to come.
Old Mar 1, 2016 | 08:50 PM
tbax46's Avatar
tbax46
After putting in a pair of 12 oz cans, the air has gotten cold
Old Mar 1, 2016 | 09:51 PM
whomrig's Avatar
whomrig
good job
go pick up a thermometer and see what temp your air is on max air
if it stays, you are good.
Old Mar 1, 2016 | 10:26 PM
WatsonR's Avatar
WatsonR
anybody have a recommendation for a set of gauges... to give the man?
Don't forget that now the A/C is working... you have a leak somewhere that needs to be found or you'll be charging again. You can add some dye to the system to see, may just be a loose connection... but I'd recommend finding it. Sometimes you can tell a leak by the oily residue left behind as the charge contains a small amount of oil, could be seen as a wet spot around the joint/connector.
Old Mar 2, 2016 | 01:48 PM
fabsroman's Avatar
fabsroman
I went through this for 6 months. I could not find the leak until I put some UV dye in the refrigerant line. Turned out that the leak was on the line going from the compressor to the condenser. Once I knew where the leak was, the repair was simple.
Already had the gauges and a vac from doing my Taurus AC a couple years beforehand. Now, they have paid for themselves several times over.
OP, as has already been stated, the on and off clicking of the AC compressor is a sign of low freon, but I think you already figured out that the system was low. As has already been pointed out, the system is a completely closed system, so if you are low on freon, then there is a leak somewhere.
What has not been pointed out is that freon and moisture cause acid, and that acid will eat up your AC components. So, when you go to add freon it is best to pull a vacuum. Moisture evaporates under vacuum and is sucked out of the system. Then, with a proper set of gauges you can close the system and see if the two sides remain under vacuum. If they remain under vacuum, then you know the system is air tight and you can add the recommended amount of freon and sleep well at night.
ranger332
2004 - 2008 F150
Oct 6, 2016 07:15 PM
SLAYER1
Jun 10, 2013 08:32 PM
ForemanES
May 19, 2008 02:19 PM
ag-ford-4x4
Jan 16, 2008 11:00 AM
barebackjake
13
Jan 19, 2005 09:27 PM
