4r100 over drive light
Old Feb 28, 2016 | 01:54 AM
Powerstoke73's Avatar
Powerstoke73
Took a 2 hour trip got of the interstate came to a stop light and the OD light starting blinking cut the truck off at the light fired it back up shifted in every gear like normal drove a little ways stopped at a light and OD started blinking again cut truck off back on light went away shifted great threw all the gears any ideas
Thanks
Old Feb 28, 2016 | 02:01 AM
killerstroke's Avatar
killerstroke
Get the transmission scanned, cheap OBD scanner won't cut it.
Old Feb 28, 2016 | 02:07 AM
z31freakify's Avatar
z31freakify
If that light blinked you will have some codes stored, normally when codes pop up its because the tranny is slipping many times the Torque converter.
Old Feb 28, 2016 | 02:15 AM
Powerstoke73
Ok I will have it scanned in a few and I will reply with what codes came up
Old Feb 28, 2016 | 11:09 AM
Powerstoke73
Ok i have a P0720 output shaft speed sensor circuit
P0503 vehicle speed sensor A intermittent/erratic/high
P0722 output shaft speed sensor circuit no signal.
Old Feb 28, 2016 | 05:30 PM
Powerstoke73
Ok so driving along today came to stop light light started blinking so out of curiosity i drove regular and it shifted in every gear and then the light went out and it repeated those symptoms until i drove him kinda strange
Old Feb 28, 2016 | 08:44 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Most likely you have a damaged and/or corroded wiring harness. It's going to be intermittent until it fails completely. This usually requires someone with the right tools and experience to find and fix the problem. A good independent shop is your best bet, dealers don't often get problems like this.
Myron Bennell
Aug 3, 2015 06:51 AM
93idi7.3
Mar 31, 2011 09:05 PM
paul1910
May 12, 2008 02:55 PM
firebug
May 10, 2006 09:47 PM
97 stroker
13
Feb 28, 2006 05:45 AM
