Anyone ever experience this issue?
Old Feb 27, 2016 | 02:19 PM
Jimmy James Orsaris's Avatar
Jimmy James Orsaris
hello guys have a 2003 excursion v10, when giving gas sometimes i hear a noise, Sounds like an exhaust leak, driving me insane, coming from the front left. i just installed a complete headers back exhaust from banks (huge difference by the way) more power.. noise is still there..
Old Feb 27, 2016 | 03:48 PM
Stewart_H's Avatar
Stewart_H
Check your spark plugs immediately to make sure they aren't loose.
Stewart
Old Mar 3, 2016 | 09:47 AM
Jimmy James Orsaris
Stewart
first thing i did. driving me insane
Old Mar 3, 2016 | 09:56 AM
LivingLarge's Avatar
LivingLarge
Did you replace the actual headers or just exhaust after headers?
Explain the noise in more detail, is it ticking sounds or just the sound of air in the header itself? Does it happen more when engine is cold or all the time?
Old Mar 4, 2016 | 07:37 AM
Jimmy James Orsaris
yes headers as well, i went with the Banks set up, with the chip. i honestly thought the noise was coming from the driver side header. but still doing the same, best i can describe it, sounds like an exhaust leak, normally does it when I'm giving it gas
Old Mar 5, 2016 | 07:40 PM
wpnaes's Avatar
wpnaes
Heat shield rattle?
Old Mar 5, 2016 | 07:43 PM
Greenscobie86's Avatar
Greenscobie86
Mine has a rattle around 2k RPM mark. I think its either the factory t-pipe resonating in conjunction with an exhaust shield rattle or a loos torque converter cover plate. Gotta get under there and check one of these days.
Old Mar 6, 2016 | 05:59 AM
WE3ZS's Avatar
WE3ZS
Jimmy James, check this too. The sheet metal torque convertor cover can vibrate at certain RPMs and give a pretty audible rattle or tapping sound. You can safely pull it off to test drive to verify if the noise goes away, if so then just give the thin cover a slight bend by hand to have it sit differently when re-installed, this will most times quiet it down.
BatistaBomber12
2004 - 2008 F150
Jul 21, 2016 11:11 AM
1975StroppeBaja
Jul 5, 2010 04:47 PM
VAXB
Modular V10 (6.8l)
Jan 28, 2010 11:03 AM
Scottay
Modular V10 (6.8l)
Dec 2, 2008 08:11 AM
ckb2steelers
Modular V10 (6.8l)
25
Jul 27, 2006 07:44 PM
