6.0L specialty tools
Old Feb 27, 2016 | 10:22 AM
Toyman's Avatar
Toyman
Is it really necessary to have these tools to main seals on my diesel.
I'm getting ready (this summer hopefully) to tear the 6.0 down and reseal it. The truck runs like a top, has supposedly had all the updates with stand pipes, dummy plugs, stc fittings, blue spring, but when the headgasakets were done they used factory bolts. If I tow heavy it will burp coolant, so I know there has to be a warped head or something along those lines, work was done at ford dealer just before I got the truck.
Anyway, I figured If I am going in there I may as well do both main seals, bedplate, and am debating on the lpop (but I really only have 123K on the truck)
Does anyone know of a place that I can get the tools cheaper? I looked at freedom racing, but they even want half the cost of the tools to rent.
Old Feb 27, 2016 | 10:41 AM
KDAVID1's Avatar
KDAVID1
Try ebay. I've gotten alot of specialty tools at a good pricee. Even some from ebay auction. You do need to search a bit to get from a reputable place but csn save tons of $$$
Old Feb 27, 2016 | 10:51 AM
npccpartsman's Avatar
npccpartsman
Yes, you really need the front and rear main seal tools to install them properly although if they're not leaking now then I wouldn't mess with them. Doing the top and bottom of the motor are two completely different operations entirely.
Old Feb 27, 2016 | 10:59 AM
Toyman's Avatar
Toyman
Yes they are.
The oil pan gasket is seeping a little along with the bedplate, I just figured while I was in there I would reseal it all.
Fellenz
Oct 6, 2016 11:49 AM
desertt5
Aug 3, 2010 09:31 AM
wreckinball
23
Feb 12, 2010 02:33 PM
kosmo01
Apr 6, 2009 07:35 PM
NightCrawler
1983 - 2012 Ranger & B-Series
15
May 16, 2008 08:05 PM
