E40D Transmission Help
Old Feb 26, 2016 | 11:32 AM
Funkypanda's Avatar
Funkypanda
Over the summer my '93 f-150 flareside with the E40D automatic transmission went out. I purchased a atsg rebuild manual and a rebuild kit and rebuilt the transmission.
I put a used transmission pump and a new torque converter and got it all put back together. When I started it up and shifted into reverse drive etc.. Nothing seemed to engage but it did start idling a little higher. Any help is appreciated thanks.
Old Feb 26, 2016 | 08:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
How much fluid did you out in it?
Old Mar 1, 2016 | 12:26 AM
Funkypanda's Avatar
Funkypanda
I believe it was around 16 quarts. I filled up the tc also
Old Mar 1, 2016 | 08:03 AM
Mark Kovalsky
That's probably not enough. What does the fluid level show on the dipstick?
If there is enough fluid, get a 0-350 PSI gauge and install it in the test port. Check the pressures at idle with the PRND21 in each position.
Old Mar 5, 2016 | 08:25 PM
Funkypanda's Avatar
Funkypanda
Yea but I did start the truck and tried to run it through the gears and I was checking the dips tick and it was quite a bit over the marker so I believe the pump is not engaging and sending fluid
Davon3598
Sep 30, 2018 04:25 PM
johnnys30
Sep 30, 2015 10:19 PM
Flea
24
Feb 4, 2009 12:20 PM
BarnYardRon
Aug 1, 2005 02:58 PM
arizonius
1978 - 1996 Big Bronco
Jan 25, 2004 12:09 AM
