1978 - 1996 Big Bronco
Spartan locker install instructions suck
Old Feb 25, 2016 | 08:39 PM
arkredneck's Avatar
arkredneck
Bought a spartan locker for the 78 bronco 9". The install instructions are crap. All the pics and instructions seem to be for like a Dana or c clip axle. With the 9" you keep the part of the spider gear assembly that the axle slides into. The instructions say you don't need thrust washers no more but it doesn't really show the 9". I'm curious if you keep the washer that goes between the carrier and the part of the spider gear assembly that you reuse. It seems like you might need it. I'm pretty sure you don't use the washers that the cross pins go threw. It's just aggravating you spend a lot of money on a product and the company can't give out a detailed instruction sheet for each axle they make a product for.
Old Feb 26, 2016 | 10:48 PM
Encho's Avatar
Encho
The Southernmost Mod
Did you try contacting them directly? The diagram you need might be available, if not, some net search might bring good results, I'm fairly sure you aren't the first to install a Spartan in a Ford 9" (which many old Jeep owners seem to love for upgrades).
Old Feb 27, 2016 | 09:06 AM
arkredneck's Avatar
arkredneck
Usagear is who makes the Spartan locker has no contact info. I bought it from summit racing called the tech line they was pretty clueless to
Old Feb 27, 2016 | 09:40 AM
gatorfor88's Avatar
gatorfor88
This place can probably help you.
https://www.ringpinion.com/
Old Feb 28, 2016 | 07:41 PM
Kemicalburns's Avatar
Kemicalburns
and there is nothing on youtube?
Old Feb 29, 2016 | 12:57 PM
arkredneck's Avatar
arkredneck
I didn't see anything on u tube. I got it installed in the carrier. I wasn't sure if you was suppose to use the washers that go between the spider gear and the carrier case it turns out you can't use it because it won't fit back together with it in
winmag4582001
Apr 26, 2017 09:08 PM
fatdan460
Mar 9, 2010 05:48 PM
drj777
Feb 22, 2007 06:49 PM
Caleb1
Offroad & 4x4
Oct 6, 2004 06:06 AM
natewoz
Offroad & 4x4
Jul 20, 2004 04:16 PM
