Bilstein leveling kit?
Old May 25, 2018 | 05:16 PM
  #46
TooManyToys.'s Avatar
TooManyToys.
Track bar is not a steering component, it’s axle positioning.
Correct, with more space between the axle and frame, the track bar rotation will pull the axle towards the drivers side. Actually any change in this spacing should require a change in length, longer. If not done, the axle is moved and the steering will need to be adjusted as it will be pointing slightly to the pass side.
If equipped with a radius arm its anchor point should also change, otherwise the caster changes. But caster and camber are adjustable on 4x4 by means of the top balljoint sleeve. So it can be possible with a minor lift to correct caster without changing the radius arm anchor.
Leaf springed vehicles dont have the radius arm worry.
Old May 29, 2018 | 10:10 AM
  #47
Sarge261's Avatar
Sarge261
Originally Posted by Mississippi013
Old Thread, but I just purchased a '16 F350 last night. Is the bilstein kit working out? Any Pros or Cons? I see that Sarge was able to get everything aligned without the adjustable track bar, but is that the case for everyone? Sarge, any issues arise from the lack of the adjustable track bar?
Thanks.
I didn't have any issues, I ran that set up on my truck for almost 11 years, should I have put an adjustable track bar on it...yes, did it bother me or make the truck handle any differently...not to me it didn't. I towed my trailers all over the east coast with it, drove it empty all over the east coast and the tires never wore funny, never ever had any death wobble, truck always tracked straight and at 80,000 miles when I sold it the ball joints, tie rods, and track bar were still tight. I was impressed with the kit and if I can find it for my new truck I may install it as well, I will however install an adjustable track bar on my new truck as the 17's its way more noticeable I'm hearing.
Sarge
Old Jul 11, 2018 | 06:44 PM
  #48
Dr Matt's Avatar
Dr Matt
No good pics yet, just bought a '17. My first dually & first Diesel. Going to be a dream towing my 40' triple axle toy hauler with this compared to my '99 F250 V10!
Old Jul 11, 2018 | 08:49 PM
  #49
Yahiko's Avatar
Yahiko
Some nice sparkle there.
dkllw1
Jun 13, 2018 06:35 AM
JoeyCap
Mar 17, 2016 11:25 AM
SILVER STROKE
Jun 11, 2008 10:21 AM
deckguy
Jan 12, 2005 12:01 AM
