If you just put in the C code the rear end will sit lower than the front. When we sell our replacement X codes up front we supplement them with our ATS Modded C code in the rear. The last thing you want to do is go through all the work of swapping everything in and finding out that the rear end isn't where you want it.
Maybe, he can try it, if it is lower, then he can mod it or switch to the tapered block.
Junior, how would it sit with the stock SRW F350 C code in the rear and V codes up front? That's what I'm considering at this point. I was looking at getting the fronts from you. I just stumbled across these C codes.
It would have a similar rake to what they did from the factory, that is exactly what I have (see my signature).
Reason: added sig comment
Thanks, Rob. That's pretty much how I wanted it to look. Factory only with more weight capacity.
You're welcome! Personally I wish my V's sat higher, I may install the overload from the rears to help pick up the front but I've never been too keen on doing that even though many have done it with good results.
So, if I decide to purchase these C codes, is all the hardware the same? Shackles, U bolts, etc?
You'll need a shorter center bolt for the spring pack since you need to remove the overload and spacer. I think most will tell you to buy new u bolts, I started with good intentions, new F250 u bolts, F250 blocks, new u bolt nuts etc. turned out the rear say way too high with the F250 block so I used mu Excursion block, Excursion u bolts but the new nuts because it was over a weekend I also cleaned up the old u bolts real well and used blue loctite. I checked the torque a few hundred miles and it was everything tight. Personally I think it's recommended to replace u bolts because they originally had a loctite patch on them. I wire wheeled mine then as I said applied loctite.
OK, I went and looked at the springs on the F350 again. They look pretty good. Hardly any rust on them at all. The kicker, though, is that they have 289,000 miles on them. Is that too many miles or are they still a bargain at $150 for the pair?
Quality springs will last longer than cheap springs. I think the good stuff is 5160, they can handle more cycles - hundreds and hundreds of thousands and still return to the exact same spot (ride height).
Eventually though even good springs will start to sag. I don't see the point in all that labor and time to install used springs that may not be any better or even worse than what's in there now.
By chance did you see a part number? If you did and it's painted on, they could be service replacement springs. Who knows, the truck may have had an easy life, is the bed beat up? Does the truck look like it had a hard life?
No, I didn't see any parts numbers on them. The truck was well worn with chunks out of the seat. I think it was a work truck. The bed wasn't really beat up or rusted, but with that many miles, I'm thinking I might be better off putting that $150 towards new ones. I can always do the rears first then the fronts. There's always the option of taking them to the spring shop in Hagerstown and having them rework them and add a leaf or two, except with that route, I'm not exactly sure what the rates, etc. would be on them.
I wouldn't rework them. You could either buy new from Ford or contact Jr at ATS for a quote.
