400 ford carb issues.
Old Feb 21, 2016 | 03:34 PM
thefordlane's Avatar
thefordlane
Guys,
The pickup im working on is a 1978 ford f150 camper special with a 400, 4 speed 4wd. 370k miles on it about 70k on this motor. Im pretty sure its the stock carb possible a motorcraft 2150 2 bbl.
Im working on my dads old 78 ford f150 i replaced the gas tank(with a plastic one) because the old one was full of rust, cleaned out the lines the best i could and put a new fuel pump and filter on it. Anyways it had been sitting for about 6ish years. I fired it up the other day and have been driving it some and it seems to load up some at an idle. It loads up really bad when im driving it unless Im accelerating or off the throttle completely, but just cruising along it chugs and sputters. Seems like its getting worse instead of better.
The automatic choke is releasing all the way and it idles at about 900 rpm.
Just looking for a little advice on what rout to take.(keep in mind im not great with carbs haha)
Thanks a bunch
Lane
Old Feb 21, 2016 | 03:48 PM
JWC 3's Avatar
JWC 3
If it sat for 6 years , you should have the carb gone through . Easy carb to rebuild .
Old Feb 21, 2016 | 03:59 PM
thefordlane
I figured that is what you would say haha. I will have to do that, or would i be better off buying a reman? At napa they want 125 for the rebuild kit or 250 for a reman.
Old Feb 21, 2016 | 05:02 PM
JWC 3's Avatar
JWC 3
WHAT $125 for a KIT ? Last I bought was only less than $30 ....
I see poor results from reman big box carbs .
I build them myself .
Old Feb 21, 2016 | 07:31 PM
thefordlane
Ya i thought that was a lot ill have to look around for a kit some more.
Old Feb 23, 2016 | 06:21 AM
ubereal2's Avatar
ubereal2
Sounds like somebody looked at something wrong. I just rebuilt my 2150 a couple of weeks ago and paid less than $20 for the complete kit. If you don't have a good car/parts cleaner get a gallon can that you can soak everything in overnight. It makes a huge difference.
Unk Bob
Old Feb 23, 2016 | 06:39 AM
Blue and White's Avatar
Blue and White
Agree rebuilding carbs is easy... if you do it often enough to be good at it and know what to watch out for. Also if the core is good and completely intact.
I don't it often enough and buy reman. An Autoline brand reman from AZ got the 400 on my '78 F250 running well.
My situation was roughly similar... truck had sat and had a bad tank and the 35 YO original carb was gummed up.
Old Feb 25, 2016 | 09:15 PM
nzirbel's Avatar
nzirbel
A good idea would be to check all vacuum hoses and connections first. My 390 was running like dog crap, stumbling, and backfiring. Had an open line and a cracked line, fixed them now it runs awesome. . While I don't doubt that your carb might need rebuilt it's worth looking at the lines first.
SteveI
Oct 27, 2007 09:24 PM
truckman79
Sep 27, 2004 11:20 PM
Brian77Ford
Jan 19, 2004 12:32 PM
dbarracuda
Nov 28, 2002 04:53 AM
AMiller320
Nov 11, 2002 08:36 PM
