carb rebuilds?
Old Nov 26, 2002 | 11:53 PM
dbarracuda's Avatar
dbarracuda
carb rebuilds?
hey guys
About how often does a carb need to be rebuilt? My 77 f-150 w/400 has a hard time taking off from a stop when its cold an I thought this might be the cause. I have already replaced the choke.
Thanks
David
Old Nov 27, 2002 | 12:00 AM
Mil1ion's Avatar
Mil1ion
carb rebuilds?
The carb that was on my 78 400 went 317,000 Km without a rebuid,and it worked great.
I think the key is *constant use*.
If left sitting ,things will dry out and need replacing.
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 27, 2002 | 12:57 AM
urif250's Avatar
urif250
carb rebuilds?
Yes, sitting idle and not running is bad for a carb. If you are running the stock 2bbl Motorcraft carb on your 400, I would consider not bothering to rebuild it. It is a bit more expensive, but there are a lot of benefits to getting a new carb, especially if your old one has a lot of miles on it and you are not an experienced carb mechanic.
-Urif250
Old Nov 27, 2002 | 05:06 PM
dbarracuda's Avatar
dbarracuda
carb rebuilds?
Thanks guys,
My carb is the stock motorcraft but I don't know how old it is. I bought the truck off an elderly man last summer. I think they said that they werent driving it much but that was a while back. I drive it most every day. Thanks again.
David
Old Nov 27, 2002 | 08:08 PM
Mike W's Avatar
Mike W
carb rebuilds?
These carbs are easy to rebuild. Take your time on the first one and pretty soon you will be able to do it with a blindfold on.
Old Nov 27, 2002 | 10:09 PM
LxMan1's Avatar
LxMan1
carb rebuilds?
Could be that the timing is too slow, or that the accelerator pump in the carb is shot. Check the timing. Should be around 10 to 12 BTDC.
Old Nov 28, 2002 | 04:53 AM
theonlybull's Avatar
theonlybull
carb rebuilds?
dmanlyr
401, 477, & 534 SD Engines
Dec 17, 2013 03:09 PM
wdmack
Feb 11, 2012 03:16 PM
dbarracuda
Jan 30, 2003 10:19 PM
54blackford
Dec 13, 2002 08:48 AM
