Need to give credit to Justin RD Performance
This weekend I changed the injectors, which I felt were going bad. Ordered just the nozzles from Justin, tried to save on shipment, got bit in the *** by the customs and tax but the result is perfect. Took me a day to assemble the injectors as I did not have many shims, so changing shims, springs over and over to get to 125-130 bars which is 1820-1880 psi. The truck runs sooooo smooth, starts like a gasser, and NO SMOKE what so ever. Better throtle response, better torque down low. I strongly recomend anybody with smoke issues to check the injectors, as mine were toast, none even attemp to spray a pattern, just dripping and straight shot of diesel from 1400 psi. Even then the truck started fine, but smoked. Smoked black going up hill, now just a slight barely noticeable haze under wot. I am sure the mileage will be better, as I wasted a lot of fuel badly burned out the tail pipe.
Not worth to bother with just the nozzles, 275 bucks for complete injectors with the old cores sent in is the best investment u can do to your truck. Thank you Justin for producing parts for our trucks!
The odd thing is, I thought it ran really well when I drove it here in the states. The timing was off but it ran smooth and clean and got mpg that would make most owners jealous. So either it was doing really well in spite of the lousy injectors, or else the injectors went south really fast after you got it to Europe. I was under the impression that injector failure was more gradual than that. Either way, I'm glad you got it resolved.
I went the stock route, Europe is more into emissions, I want as less smoke as possible. I do not want race hp, just the reliable rig. The next is the IP 90cc pump, still deciding if 90 or 110.
I'm pretty sure that the fuel in the EU is different than the US fuel. They are both "Diesel", but I think the cetane numbers and such are different. This means that the timing should be different over there vs over here. ( https://en.wikipedia.org/wiki/Cetane...Typical_values )
Injector failure /should/ be slow, but I'm wondering if running it off-timed/smokey caused some of the injectors to coke up with carbon, and thus not seal correctly, making the problem even worse.
Sure, the pop pressure would still be low(er), but that wouldn't be a problem with proper timing compensation.
You can then adjust it for little to no smoke, without sacrificing power at the high end.
Even here in the US, I'll be going for one -- as it is now, I have to be really light with my foot in the lower revs when I don't have turbo boost available. I can't just floor it under about 2200RPM.
If you are going turbo(I think you are, right?), I'd look into getting a 110, and installing one of these: https://www.gohypermax.com/ProductDi...5-a3a12867ecce
I can't just floor it under about 2200RPM. Well I do not get that up the rews, I am shifting around 2000rpm.
Sidewinder still in the box in my garage.
Where do you mount this sucker on the pump? We get emission restrictions in the cities, basicaly no gasser under 1998 and diesel under 2000 can enter the city center since the 2017. However antique cars are exempt.
fuel injection injection pump injection pump rebuilding injection pump repair, Conestoga Diesel Injection Fuel Injection and Turbocharger Rebuilding. The Moose Pump people! Willow Street, PA Ford
I think 110cc is way too much fuel for the Sudewinder TE06H... or perhaps more correctly the TE06H is way too little turbo
Yeah, it'll work on a 110. It simply pushes against the metering valve limiting max fuel, kind of like the "torque screw" did.
As for it being too big... eh, slightly. But the TE06H can use at least 100CCs of the 110CC pump. Once I got mine adjusted correctly, I'm pushing 22 PSI of boost out of it; with a stock pump I pushed perhaps 12. I figure you can always limit the fuel(a 110 CC is a DB2 through-and-through, just with some tweaks) if you need to. Or just learn to use your right foot appropriately.
I guess i wasnt so concerned about it working on a 110 pump, as i was if it would work correctly with the extra boost that would come with it 15psi vs. 30 for instance. No idea how theyre designed, i assume just a spring loaded diaphragm, that like you say, just pushes on the metering valve to limit fuel to a certain extent.
I looked at the plans(CARB requires a bunch of documentation, and google found it), and yes, it's just a spring and diaphram. And it's all adjustable; you have to adjust it normally till you have it working properly. With a 110, same deal - adjust until you have little smoke while still getting full power under boost. Worst case, you might need to use a different spring, but probably not.
Have you used one? I dont want to limit power, but being able to make it so it doesnt roal coal, or even a failsafe for EGTs to an extent if someone other than me was driving it.
I don't have either right now.
