New truck new problems
Old Feb 21, 2016 | 01:50 AM
Oldsman003's Avatar
Oldsman003
Question New truck new problems
Ok all question, new truck
2005 Expedition XLT 2wd 204k 5.4l 3v 4r75e
The issue
When I take it out of park every gear is neutral it has nothing in any selected gear no reverse drive second or first. Nothing if shifted manually nothing at all it will only Rev. The guy I bought it from just changed fluid and filter hoping for a change and nothing.
What could be causing this. It seems very odd it won't have anything out of park.
Old Feb 21, 2016 | 11:50 AM
Skauber's Avatar
Skauber
Unless the shift cable is broken (unlikely since you say you're able to shift out of park), then most likely bad transmission. What can fail which gives you a "dead" transmission? Many things, oil pump perhaps, or it may be something else. In most cases, it means you need to get a rebuilt transmission and swap it out.
Old Feb 21, 2016 | 12:13 PM
Oldsman003's Avatar
Oldsman003
I figured the pump went out, I'm glad it's a common trans.
Old Feb 22, 2016 | 04:08 PM
alloro's Avatar
alloro
Fortunately is 2WD and you don't have a transfer case to deal with.
Old Feb 22, 2016 | 07:48 PM
Oldsman003's Avatar
Oldsman003
I have found a 4x4 trans, will it work in a 2wd application? What would need to be changed if anything
Old Feb 23, 2016 | 12:10 AM
alloro's Avatar
alloro
The outputs are different since one takes a driveshaft and one bolts to a transfer case.
Old Feb 23, 2016 | 06:55 AM
Skauber's Avatar
Skauber
I do believe it's possible to convert it, i.e. swap over the output "neck" or whatever they call it. But not sure how much is involved in doing it, and if it includes opening the whole transmission. A factory shop manual would be able to give an answer to that if you study the blown out diagram of the 2wd vs 4wd transmission. A deal breaker would be if the output shaft is different and if that has to be taken out through the front of the transmission...
Old Feb 23, 2016 | 07:31 AM
Oldsman003's Avatar
Oldsman003
I wish I had both side by side, but transmissions are a bit too pricey to just buy to look....
L0gan
Mar 8, 2018 09:21 AM
anton5052
Oct 15, 2017 08:12 PM
Walkerman
Dec 14, 2009 09:34 PM
tom685798
Feb 9, 2004 02:22 AM
