Transmission won't shift into reverse
Old Mar 6, 2018 | 06:26 PM
L0gan's Avatar
L0gan
I have a 1997 ford expedition with a 4.6l 4wd it has a 4r70w transmission. I have recently started having problems with this transmission such as when I shift into reverse and press the gas it goes forward and same for every other gear. Park is the only gear that still is working .Does anyone have an idea what might be going on or does it just need a rebuild?
Old Mar 8, 2018 | 09:17 AM
alloro's Avatar
alloro
You sure the linkage is adjusted correctly?
Old Mar 8, 2018 | 09:21 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the linkage is connected all the way from the shifter to the manual valve inside the transmission pan, the trans is all done and needs a rebuild.
jas88
19
Sep 9, 2015 08:43 AM
69-390f100
Sep 24, 2005 05:41 PM
chevyhater74
1983 - 2012 Ranger & B-Series
May 28, 2005 01:46 PM
M.Stephens
Mar 22, 2005 12:44 PM
