Accelerator Pump Leak
Old Feb 20, 2016 | 05:04 PM
bmarble12's Avatar
bmarble12
I have pretty much adopted my grandpas 68 F100. I don't know anything about its history, but i drive a several times a week to keep everything in order. I noticed a fuel leak coming from the accelerator pump. It is leaking pretty good.
A friend said he replaced his diaphrahm and it fixed his leak. Will I need to identify my exact carb before buy i a new diaphraham and check valve. If so, how do i identify it?
Old Feb 20, 2016 | 05:36 PM
RichS2659's Avatar
RichS2659
It is a common Autolite/Motorcraft/Ford 2100. You can get a kit or just the pump at an auto parts store or your Ford dealer.
Old Feb 20, 2016 | 05:46 PM
Tedster9's Avatar
Tedster9
Yep the kits are designed to fit a wide variety of carbs. It's worth looking over some of the carb rebuilding videos and familiarize yourself with the kit instructions. A can of good carb cleaner and shop air to blow out the orifice and such. New power valve etc. Easy peasey.
Old Feb 20, 2016 | 09:10 PM
kenny nunez's Avatar
kenny nunez
pump diaphfram
Before you re install the cover make sure the mounting edges are flat, rub it over some sand paper on a flat surface to check it.
Old Feb 20, 2016 | 09:26 PM
orich's Avatar
orich
The biggest mistake for a newbie is while putting it back together is not latching down the float retainer pin. A good way to know if you forgot or not is gas will come flooding out the top vent tube or cover vent hole.. No flooding gas your good to go.
Orich
Old Feb 20, 2016 | 11:52 PM
JEFFFAFA's Avatar
JEFFFAFA
They were the same diaphragm and cover gasket assembly up through 1974. Was Grandpa's truck sitting around unused since the newer oxygenated gas came out?
Old Feb 21, 2016 | 12:07 AM
GaryKip's Avatar
GaryKip
I just finished rebuilding my carb(same as yours) for FYI, the NAPA rebuild kit is 2-5585. The UPC is: 707390786896
Old Feb 21, 2016 | 09:24 PM
bmarble12's Avatar
bmarble12
I dont know a lot about the truck, but if i had to guess i would say yes.
Old Feb 21, 2016 | 09:25 PM
bmarble12's Avatar
bmarble12
Thanks! It doesn't get any easier than someone giving you a part number.
Old Feb 22, 2016 | 12:26 AM
JEFFFAFA's Avatar
JEFFFAFA
The old rubber diaphragms didn't blend well at all when the new gas came out. So plan on buying a current replacement fuel pump soon. As a Ford parts man then and now I wish I had a dollar for every carb kit and fuel pump I sold back then because of this. I'd be retired and sitting around on the beach sipping on an adult beverage with an umbrella in it with Bajafishnut at his place.
Old Feb 29, 2016 | 08:21 PM
bmarble12's Avatar
bmarble12
Thanks! Got it fixed, the old diaphragm are two slits in it causing it to leak, fixed in about 2 minutes.
Maybe i should start another post, but can i install a tachometer onto this 68 F100? 390/c6 Im not even sure how high this engine revs because i have never been in one with a tach.
Old Feb 29, 2016 | 08:44 PM
Tedster9's Avatar
Tedster9
Absolutely! Many of the aftermarket tachs are selectable for 4, 6, or 8 cylinders. They just need a ground connection to the coil at the negative terminal, a hot connection, etc.
Old Feb 29, 2016 | 09:21 PM
orich's Avatar
orich
A 6k tach is all you'll need as that engine will never see this high of rpm range as it is.
And a dash mounted vacuum gauge also is a good meter to have for milking out the gas mileage and keeping your engine in it's best working range.
Orich
Old Feb 29, 2016 | 10:12 PM
bmarble12's Avatar
bmarble12
Orich
Will a universal tach and vacuum gauge work, or should I try to be more specific (Im always skeptical if universal parts are actually universal). I would like to have them, but ill probably just conveniently mount them under the dash somehow to preserve the original interior.
Old Feb 29, 2016 | 10:59 PM
orich's Avatar
orich
Most tachs can be mount on the steering column.
Trouble with mounting at bottom of dash is you can't keep your eye on it.
Orich
Wbruiser2
Dec 19, 2013 07:35 AM
mythbustingpyro
Sep 23, 2013 11:31 AM
JGreen236
25
Jul 29, 2013 06:16 PM
stormdraconis
Mar 9, 2010 01:47 AM
76 F-150 390FE
Apr 21, 2008 05:50 AM
