Holley Carb question
Old Dec 17, 2013 | 07:43 PM
Wbruiser2's Avatar
Wbruiser2
Does anyone know the technical nomenclature for the item circled in the pic? It's leaking fuel.
Old Dec 17, 2013 | 07:56 PM
jsutton's Avatar
jsutton
Are you sure its not leaking from the bowl gasket right there? That's where mine was leaking from.
Old Dec 17, 2013 | 10:13 PM
JP3's Avatar
JP3
That is a plug where they drilled the passage that flows fuel from the accel pump to the squirters. It should be tight and not leak.
Old Dec 18, 2013 | 08:53 PM
tbear853's Avatar
tbear853
I have had a carb leak at plugs many years ago .... cleaned real good, spotlessly with 2+2, applied epoxy, cure, no more leak. Can't hurt.
Unusual for those plugs in Hollys to leak .... most likely a gasket leak. That's where a passage is drilled to redirect the accelerator pump shot upwards to the shooters.
Old Dec 19, 2013 | 05:13 AM
Wbruiser2's Avatar
Wbruiser2
It's called a metering block pump passage plug.
Old Dec 19, 2013 | 07:35 AM
earthquake68's Avatar
earthquake68
I think it would be easier to replace the metering block, or just epoxy over the plug.
kishkumen
May 25, 2014 06:54 AM
JGreen236
25
Jul 29, 2013 06:16 PM
davewave649
Apr 30, 2013 11:12 PM
brad1979
Jun 17, 2010 05:15 PM
CN Spots
Jun 12, 2008 10:27 AM
