ABS Sensor
Old Feb 20, 2016 | 02:18 PM
Tideman's Avatar
Tideman
ABS Sensor
Is the ABS Sensor on the rear differential screw in, or just press fit. I took the 10mm bolt out, but don't want to screw up the sensor.
2006 6.0
Old Feb 20, 2016 | 05:31 PM
AL`'s Avatar
AL`
I'm looking in my Workshop Manual and don't see any threads on the sensor pic, just the bolt and the electrical connector attached to it and you should be able to pull it out as it looks like a straight cylinder below that. If it seems tight, you might lightly twist it back and forth as you pull. (Note: I've never done this, just relaying info from the manual and what I can surmise). See instructions from the Workshop Manual pg 206-09-25 below:
1. Disconnect the battery ground cable.
2. With the vehicle in neutral, position it on a hoist.
3. Disconnect the rear axle speed sensor electrical connector.
4. Note: Do not apply force to the plastic rear axle speed sensor connector.
Remove the bolt and the rear axle speed sensor.
- To install, tighten to 15 lb-ft
5. To install, reverse the removal procedure.
Old Feb 20, 2016 | 05:33 PM
Tideman's Avatar
Tideman
Al. Thanks a bunch. Didn't want to break it.
Old Feb 20, 2016 | 06:28 PM
Jerky's_06 F350's Avatar
Jerky's_06 F350
When I pulled the sensors on my chevy, then took some wiggling to get them out. Only thing that held them in was the bolt and dirt around the o ring. I gently squeezed with a pair of channel locks, pulled and wiggled them out.
John
Old Feb 20, 2016 | 11:12 PM
87crewdually's Avatar
87crewdually
Twist it back and forth and pull up. It's o-ringed.
agryphon
1983 - 2012 Ranger & B-Series
Apr 7, 2019 04:54 PM
jayrob1989
Jan 14, 2011 10:43 AM
gestu
2004 - 2008 F150
Mar 13, 2008 11:48 AM
txplayboy001
1997 - 2003 F150
Apr 16, 2006 10:13 AM
cajunplatypus
Sep 26, 2003 07:48 AM
