ABS Speed Sensor question
Old Jan 13, 2011 | 10:33 PM
jayrob1989's Avatar
jayrob1989
Replacing the rear speed sensor on my 2001 Navi. Got the sensor bolt removed and worked the sensor our of the diff. Question - what is the trick to getting the wire unplugged - it feels like it is going to break if I pull to hard and there does not apear to be a squeeeze to release or anything. Any ideas or help appreciated.
Old Jan 14, 2011 | 10:30 AM
dirtmonkey11's Avatar
dirtmonkey11
You could try taking some penetrating fluid or wd40 and spray it on the connection, sometimes this will break up the corrosion in the connector and will make it much eaiser separate. Before you start pulling make sure all the clips/retainers etc are not holding the connector on, some are hard to release but they will break if you just pull on it. Good luck, hope this helped.
Old Jan 14, 2011 | 10:43 AM
jayrob1989's Avatar
jayrob1989
Thanks, I can see that there are tabs on the new part - but the plug on the old one is completely covered so I can't really tell how the clips or retainers work. Should it just pull off or is there a trick to release? I will spray some WD as well - good idea!
gairforce1
Sep 22, 2011 09:37 PM
tom_foreman
Aerostar
May 9, 2006 09:40 PM
lwpman
Apr 28, 2004 08:41 PM
acastignetti
Mar 8, 2004 06:11 AM
whiteboyslo
Nov 6, 2001 04:19 PM
