hey guys, im doing the oil pan gasket and the torque spec is 10-12. both my torque wrenches only go as low as 20 ft-lbs. should i purches one that goes that low, maybe in inches? or should i be fine just getting it snug?
dthut, define "snug". What is snug to you may be either loose or too tight to me. That is the reason torque specs are supplied for bolted fasteners. Buy yourself an inch pound torque wrench with a usable range for the applications you will be using it for. The torque you will be applying should fall in the middle third of the wrenches range. Remember that 12 inch pounds is equal to 1 foot pound.
As a matter of fact today I needed to torque something below the minimum 20 Ft lbs available on my Ft lb torque wrench. Glad I had a inch lb torque wrench in the tool box.
Guess you might be able to the local parts house and borrow or rent one? Even better, go buy an inch lb one and convert. That way you can cover all required torque ranges.
10 Ft lbs ='s 120 inch lbs
12 Ft lbs ='s 144 inch lbs
Oil pan is not something you want to over torque and bend the lip on.
Craftsman has a nice 3/8 drive inch lb torque wrench.
I would and I did. It cost me $52.00 on Amazon.
I have a 2004 sable ls. Needed 12lbs torque for trans bolts. It was leaking because of being over torqued by the previous owner. Just like my oil pan gasket swollen out leaking on my 1993 f150 4.9 because it was over torqued. Nothing is leaking.
It's a 1/4 inch drive. 8mm bolts on my sable, 13mm bolts on my f150.
Buy it, its worth th he money.
I use a lot of "snug" like for 5/16" fasteners through a cork gasket. I use torque wrenches for like engine bolts into castings like oil pumps, rod caps, main capa, heads, wheel studs & bolts usually but not always, etc. We used to build cars to race and use a TW on head bolts and bearing caps, not even on intake bolts. I reuse a few bolts too.
Test your skills on a oil pan gasket. The most important thing is to get all the bolts tightened in a cross cross pattern so it tightens up evenly. Don’t need to tourque wrench the pan just get it on even and tight if u get crazy your gasket will start squirting out and then you may have a leak again. Sometimes you might need to do it twice but that’s how you learn at least that’s how it’s been for me
No torque wrench for low setting? Use 1/4 inch wrench set stubby handle, give you a lot better feel. way lower torque for small fasteners. Use 3/8 torque wrench for anything larger like manifolds and connecting rods. Use 1/2 inch for mains and heads or suspension. Just my thoughts, middle of the scale reading on wrench good rule to follow for the job.
I remember reading in both catalogs a lot years ago, that a standard 3/8" ratchet 8" long used with one hand by an average person, can do 30 lb/ft. So I would agree with others that a stubby 1/4" ratchet if you don't want to buy another torque wrench.
