Fuel Line Replacement + Part Number HELP!!
I am troubleshooting a fuel smell, stall issue.
I got a OEM fuel filter and attempted to switch it out.
Very long story short, I cut off the filter and it doesn't look pretty.
I need to replace my fuel feed line? (The line that goes from filter to rail/injectors).
Can someone kindly confirm that it is called a fuel feed line and maybe a part number?
Also, how easy/hard is it to replace? Anything to look out for? can it be done with normal tools? It looks a little unusual.
I opened the doghouse and saw that the line has a plastic attachment and it does not appear to be a simple removal. Didn't make too much sense of it, I must have inhaled a gallon of gas while under the van...
Any help would be appreciated. Thanks.
IF you have that info just in a signature keep in mind some disable those so they don't display. Its a good practice to list important details in order to get the best help here.
