junk fuel line
Old Dec 29, 2010 | 04:35 PM
deere55's Avatar
deere55
junk fuel line
Does anyone know where to get the fuel line that runs from the fuel filter to the center of the ip? Mine was leaking and it looks like the O ring in the fitting is all chewed up. I've had the ip out 4 times in the last 12 months and I think a combination of age and over use finally wore it out.
Old Dec 29, 2010 | 06:57 PM
1994F2507.3L's Avatar
1994F2507.3L
you can get replacement o rings from ford for 3 or 4 bucks need a pick to get the old ones out.... i did it
Old Dec 29, 2010 | 07:02 PM
deere55's Avatar
deere55
I'd like to see how much the line is, the threads are looking kind of bad too...
Can anyone help me out with the part number of that line?
Old Dec 29, 2010 | 07:14 PM
1994F2507.3L
Old Dec 29, 2010 | 07:19 PM
1994F2507.3L
sorry for the double post... if i remember right you can get the lines from international for about 50 bucks a piece someone told me... i don't know the part number though
Old Dec 29, 2010 | 08:43 PM
johnboggs21's Avatar
johnboggs21
can probly get another line from a jyard for a few bucks........
Old Dec 29, 2010 | 08:51 PM
PLC7.3's Avatar
PLC7.3
Fuel line seals--filter to injection pump E3TZ-9K260-A (EA 2) 5/16 ID
Fuel line seals--fuel filter inlet E3TZ-9C387-A ((EA 1) 3/8 ID
Any diesel shop would have seals.............. Check the wreckers for the steel line.
Old Dec 30, 2010 | 10:06 AM
kenpobuck's Avatar
kenpobuck
The seals are a straight walled design sorta like a piece of small rubber hose. If you can't find them at a ford dealer near you you can go to a good hardware store and find them. It is not only a seal but also a vibration isolator. I can't remeber the actual name of them but they are used on other applications as well.
Old Dec 30, 2010 | 01:34 PM
rodneywar's Avatar
rodneywar
it is called vibra-lock parker has them as well
Old Dec 30, 2010 | 10:39 PM
fordhorse's Avatar
fordhorse
the part # is on this
https://www.ford-trucks.com/forums/p...ictureid=46632
IH can get it for you or ford i got mine from a ford/peterbilt dealer i think it was $20 order an extra seal because mine only came with 1
Old Dec 31, 2010 | 06:39 PM
BlueOvalBud's Avatar
BlueOvalBud
The line from the Fuel Filter to the IP is low-pressure.
The parts truck I bought must have had a busted line also because each threaded end was screwed into their places with rubber fuel hose in the middle.
Seals, the other guys got ya covered on those.
Old Jan 2, 2011 | 08:16 AM
dyoungen's Avatar
dyoungen
I had the ame problem shortly after I got my 87 f250. I replaced the fitting in the IP with a barb fitting and used regular rubber type hose fuel line to hook the pump to the IP.
Etone
Jun 17, 2016 09:06 PM
vernon71
33
Apr 15, 2016 10:07 PM
DarkOverCast
May 20, 2015 06:59 AM
jmuenchow
Mar 4, 2015 10:37 AM
rjrandy96
20
Nov 25, 2013 06:53 PM
