Fuel line segment..
Old Jan 20, 2015 | 05:03 PM
gman97005's Avatar
gman97005
Fuel line segment..
that runs from the fuel filter > forward > to the ?, maybe fuel pressure regulator, rail, not sure..
not sure where it ends but my friend ruined it trying to change my fuel filter.
I need this line but have no idea what part number or where to get it, help please..
92 e150 351 windsor EFI
Old Jan 20, 2015 | 06:41 PM
Wildman25's Avatar
Wildman25
That line runs from the fuel filter to the fuel rail.
The return line comes off the pressure regulator.
Both are braided Stainless Steel lines.
I dough that the line is available?? A lot of parts for our era are depleted or discontinued.
So, choices are, pick-n-pull, junk yard, Or........I'm parting out a '92 E350 351W cut-away.
Drop me a PM with your shipping address, You pay the fright, and I'll box it up and ship it out.
Just make sure you have a set of these for taking the quick connects apart-
Also, at the fuel rail, hit the fitting spring with a blast of PB before you try to disconnect it.
Old Jan 20, 2015 | 09:00 PM
gman97005's Avatar
gman97005
Thank-you, i called Ford and was told the line is obsolete and no longer made, they did say to bring the line to the dealership and they will repair it.
I am wheelchair user and have to depend on other people more than i would like, i gave him instructions and showed him how the tool worked and when i came back 30 minutes later he told me the front line would not stay attached after clipping it on, i got down on the ground and there were plier marks all over the fittings and i just about lost it, he trashed the connector forward of the filter.
He says, can't you put a hose clamp on it.
Old Jan 21, 2015 | 05:14 AM
Wildman25's Avatar
Wildman25
OK, I understand.
See how you make out with getting the fitting/line repaired.
Dorman do have the replacement fitting for the upper end, to the fuel rail, but not the filter quick connect fitting.
Just let me know if you still need this line, my offer still stands.
tlk401
1983 - 2012 Ranger & B-Series
Dec 13, 2022 02:50 AM
ItsAFord55
1997 - 2003 F150
Aug 6, 2013 06:07 PM
Onus
Oct 20, 2012 10:01 PM
COMET909
Nov 17, 2005 08:07 PM
deondanno
Jul 24, 2002 11:48 AM
