SCT X4 HELP
Old Feb 19, 2016 | 07:55 PM
Outrigger Reef's Avatar
Outrigger Reef
SCT X4 HELP
Want to get some custom tunes for my sct x4. Turned on the tuner to get the strategy code and it says no ECU code.
Not sure what to do. Truck is a 2006 6.0.
Back in the summer my Ficm voltage was low so I pulled it off and sent it in to ficm repair. Got it back and everything was great. Now when I did this I am not sure I put the stock tune back in before removing it. Is this the issue and if so what is the fix?
I am able to put the can tunes in and back to stock no problem.
Hope someone can help.
Thanks in advance.
Old Feb 19, 2016 | 08:15 PM
TooHuge's Avatar
TooHuge
If you're running those canned tunes, you need to return your truck to stock before the strategy number will show up.
Old Feb 19, 2016 | 08:18 PM
Outrigger Reef
I think I did that when I went to the default setting and changed the tune. Is that correct?
I didn't drive the truck after that, just changed the tune in the driveway.
Old Feb 19, 2016 | 08:26 PM
TooHuge's Avatar
TooHuge
There is an option before the tuning options that says "return to stock." If you have done that right the marry to the tuner will be removed and then you should be able to look up the ecu strategy
Old Feb 19, 2016 | 08:39 PM
Outrigger Reef
You were right. Thank you so much for your help.
No way could I own this truck without this site and the people on here.
Old Feb 19, 2016 | 08:42 PM
TooHuge's Avatar
TooHuge
hunt1moore
Modular V10 (6.8l)
May 18, 2017 09:07 AM
Outrigger Reef
Aug 8, 2016 09:00 PM
oxt127
Mar 13, 2016 12:26 PM
BuCKxWiLD
Mar 16, 2010 09:54 PM
ALEXVB22
Apr 27, 2008 10:32 PM
