Modular V10 (6.8l)
OBD code PO602 and SCT tuner
Old May 15, 2017 | 08:49 PM
hunt1moore's Avatar
hunt1moore
I have had the PO602 code for a while now and was told it was because of my SCT tuner from 5-Star. Should I be worried about this? It's making me wonder if this is the culprit of my 3rd gear hard shifts. My accumulator valve body is good.
Old May 15, 2017 | 08:58 PM
pauldubster's Avatar
pauldubster
The code means you have a PCM programming error. I'd get in contact with 5-Star or you might try returning the tune to stock and then reloading the custom tune.
Old May 16, 2017 | 07:23 AM
hunt1moore's Avatar
hunt1moore
I tried reloading with no luck. I wanted to see if there were any solutions before I contacted 5-Star.
Old May 16, 2017 | 08:57 AM
rock2610d's Avatar
rock2610d
I would be intrested in what 5 Star says.
Is it possible your stock tune was not stock?
Old May 16, 2017 | 10:16 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The first thing you should do when you have a tune problem is contact the company who sold you the tuner
Old May 16, 2017 | 08:19 PM
hunt1moore's Avatar
hunt1moore
I really don't know that it is a tune problem. I read a few post where it was suggested that the tune caused the code to show up. I contacted 5-Star and they suggested a phone conversation with the makers of SCT. I called them and they said that the code was not likely caused by the tune. My next step is have the dealer re-flash it.
Old May 17, 2017 | 03:39 PM
pauldubster
Do you get the code when you run it with the stock tune?
Old May 17, 2017 | 03:47 PM
hunt1moore's Avatar
hunt1moore
Yes.
I have been real busy the last couple of days but tonight I will (like SCT suggested) disconnect my battery and turn on the key a couple of times then let it sit for 10 minutes or more. He said that this might clear it up. However, I made an appointment with the dealer next Tuesday to get a re-flash anyway.
Old May 18, 2017 | 09:07 AM
hunt1moore's Avatar
hunt1moore
OK, so I cleared my PO602 code, returned the tune back to stock and then disconnected the battery when I got home from work yesterday. Cycled the key on and off a few times and let it sit overnight. Hooked everything back up and drove into work then checked my DTC and no PO602 code (however it now shows PO1000). I guess I wasn't doing it right before? I'm going to drive it stock until Monday then re-load the SCT tune and see if that throws the code again. Third gear shift seems better from just a short drive. I'll know more about that on my way home today.
pin8246
Jul 12, 2012 04:48 PM
04F-250mark
Feb 19, 2010 11:56 AM
jac08f250
Jan 27, 2009 07:26 PM
tp_taylor
Aug 21, 2006 10:20 PM
mstennes
Computer Chips & Tuners
Dec 16, 2004 02:23 PM
