Power Upgrade Time
Old Feb 19, 2016 | 05:03 PM
dizzyfingers03's Avatar
dizzyfingers03
Power Upgrade Time
So, I know we see these theads a lot, but you folks always seem to enjoy spending other peoples money :-P I thought I'd get some advice to make sure I haven't missed anything.
Budget is around $2,500 and I'd like to be somewhere around the 300HP/650ft-lbs mark (rear-wheel) Truck currently only has a decent exhaust (noise before power ).
I'm thinking Jim's stage 1s, decent tunes (recommendations welcome), 6.0 intercooler (have), upgrade to SD UVCH and plugs, SD plenums, and SD spyder (have).
For now, I'm planning to keep the stock mechanical fuel pump (e-fuel when this b*stard dies again). I'll probably do 17 deg HPOP soon. If I'm not 100% happy with this, I'm open to S366 or 475 turbo swaps later on (with the e-fuel).
All I do is tow and haul with the girl. I'd like to be able to get out of my own way when I'm grossing 20K+ on the interstate. That's why I'm not wanting race-truck power.
Thoughts/suggestions?
Old Feb 19, 2016 | 05:57 PM
z31freakify's Avatar
z31freakify
Look at my signature, perfect for, towin, daily, and sometimes light to light speedster.
Old Feb 20, 2016 | 11:54 AM
fordman67's Avatar
fordman67
Do the hpop,efuel first IMO you want healthy fuel and oil to nice fresh injectors.
Don't look at my mods...I'm an idiot
Old Feb 20, 2016 | 05:43 PM
ReBilld's Avatar
ReBilld
I agree with Aaron. The power upgrades will be a nice addition to all the work you have put into your truck already! Looking forward to this build!
Old Feb 20, 2016 | 06:14 PM
Jarrett Campbell's Avatar
Jarrett Campbell
*buckles up* lets see this Buck$zooka in action
Old Feb 21, 2016 | 06:41 AM
dizzyfingers03
Would e-fuel/hpop + tunes on stock injectors deliver much of a performance upgrade? Or should I just plan on poneying up for everything?
Thanks for the inputs.
Old Feb 21, 2016 | 06:42 AM
dizzyfingers03
Thanks. Wait until I get around to painting the old gal My wife has been suggesting pearl white with medium blue accents.
Old Feb 21, 2016 | 08:26 AM
ReBilld's Avatar
ReBilld
Since you tow the way you do, I would go with Stage one injectors, S366 turbo, HPOP, e-fuel, IC, head studs and valve springs, and a chip. That is gonna give you a proven solid towing set up with plenty of power and still be able to manage EGTs. A lot of these guys are using the Hydra chips now because you can just buy the tunes from several different tuners, have then emailed to you, and load them on the chip yourself. This gives you the option of trying out several different tunes from different tuners so you can find the ones that work the best for you. I think they can hold something like 17 tunes.
I think what Aaron meant was, if you are doing this in steps, then do the e-fuel and HPOP first.
Old Feb 21, 2016 | 10:08 AM
fordman67's Avatar
fordman67
Yes IMO it's like building a house. You need a good foundation. When I did them I could tell a difference. I picked up 10 lbs of boost. My fuel pressure would drop from 75@ idle to 30 on a hard wot pull. Mt hpop was prob on its last leg as well. It all depends on your truck but I felt that with exh ,intake, chip for mostly stock it ran well.
Made 200hp and 365 tq at the wheels on a very historically stingy dyno.
T diesel
6.2L V8
Nov 9, 2015 05:48 PM
anthonygazz
6.7L Power Stroke Diesel
Jun 30, 2015 07:24 AM
genthree
Aug 30, 2009 08:35 AM
shark1979
19
Jun 7, 2009 10:40 PM
seattleswimboy
18
Aug 28, 2008 11:57 PM
