Fuel filler tube to rear tank
Old Feb 19, 2016 | 11:54 AM
William's Avatar
William
The rubber hose inside the fuel filler tube is broken off even with the end of the fuel filler tube. When filling my new 38 gallon tank fuel splashes out and I must fill the tank very slowly. I'm thinking I could remove the tube and using a hole saw remove the entire unleaded nozzle flapper and the complete rubber hose. This, I believe would allow fuel to run into the tank unrestricted and allow air to escape via the now larger fill tube opening. Any thoughts on this idea or other possible solutions to slow filling and splashing fuel? I would think that air pressure buildup would go through the pressure valve on the top of the tank and either out to the charcoal canister up by the engine or simply escape to atmosphere out the other vent line ( there are two hoses on a 7.5 fuel pressure valve).
Old Feb 19, 2016 | 02:43 PM
sgip2000's Avatar
sgip2000
Spectra has replacements available.
Krisx125
Aug 31, 2010 07:28 AM
chas4x4
Nov 4, 2009 06:43 PM
hotelf150
Jan 8, 2004 11:21 AM
swall
Aug 7, 2003 02:06 AM
