6.0 Blue Spring Kit
Old Feb 18, 2016 | 05:17 AM
EARLYTIMES's Avatar
EARLYTIMES
6.0 Blue Spring Kit
I received the blue spring kit for the fuel pressure cap in the mail yesterday. After viewing a couple of how-to videos in an attempt to install this coming weekend, I still do not see where the "green" o-ring goes. I assume from the videos the "orange/tan" on-ring is for the fuel line supple and the "black" o-ring is for the small plastic "receiver" piece that goes into the fuel filter housing. Where does the green o-ring go?
Also I have read the 4 torx bolts can snap off if installed too hard, does anyone know the torque value for these bolts?
Any information and any tips for this install would be appreciated.
Old Feb 18, 2016 | 06:38 AM
SDER1's Avatar
SDER1
I replaced mine with a small o ring kit from riffraff diesel about 4 years ago due to the cover oring leaking. The kit came with various orings and i did not need all components. IIR correctly from mybresearch then, itvwas recommended to remove the cover and match the components with the kit. I dont remember the torque spec but it was made snug, sunce you have an oring. No leaks to date. Also, take the time to remove the CAC tube. If plastic, use a heat gun or hair dryer around the intake housing and again on the plastic end of the CAC tube. It will slide on/off with ease and less worry of cracking - mine did and now have a metal tube. Best of luck.
Old Feb 18, 2016 | 06:44 AM
EARLYTIMES's Avatar
EARLYTIMES
Thanks for the input. Any others out there??
Old Feb 18, 2016 | 11:11 AM
Mcrafty1's Avatar
Mcrafty1
Same here as the last poster. I matched my pieces with my original and I didn't torque my screws but just snugged them up, it's also an o-ring under the cap so no need to crank em down very hard. The kit comes as a universal kit so all pieces probably won't go in every application. I don't know the correct torque value for the cap.
Don't struggle with it too hard, it's not rocket science But do place wire tie or the equivalent on the fuel line behind the nut so you wont see it disappear down the fuel line and then have to fish it out of there.
Old Feb 18, 2016 | 11:14 AM
EARLYTIMES's Avatar
EARLYTIMES
OK thanks very much
Old Feb 18, 2016 | 02:39 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Here's a little info.
https://www.ford-trucks.com/forums/1...ue-spring.html
Old Feb 22, 2016 | 07:39 AM
EARLYTIMES's Avatar
EARLYTIMES
Install this weekend went very well, thanks for the support. One tip: as many posts have said the removal of the CAC tube is a royal pain; in lieu of removing and replacing the CAC tube, I simply removed the 4 black bolts that hold the "metal intake" looking thing that the CAC tube is secured to, then loosened the 7/16" clamp that holds the CAC tube down at the bottom and then just "rolled" the metal intake and CAC tube up out the way to access the fuel regulator cap.
Hope this may help others.
Old Feb 22, 2016 | 08:46 AM
rattleNsmoke's Avatar
rattleNsmoke
I removed my intercooler tube yesterday for an unrelated project and yes, it's best to use heat on the plastic and it will slide right off. I used a craft heat gun...VOILA!
Old Feb 22, 2016 | 09:36 AM
silverbullet6oh's Avatar
silverbullet6oh
For me, getting it off has never been the hard part. Putting it back on when the outside temps are low, now thats a different story.
Old Feb 22, 2016 | 03:35 PM
diesel_dan's Avatar
diesel_dan
Yeah, and if you forget to tighten the clamp down you'll get the same crap-in-your-pants scare I did as soon as you hit boost and it goes BANG and pops off!
My little tip on this job was to not break the fuel line -> regulator cap loose and instead take the hard fuel-line clamp loose down in front of the engine -- the cap and all just swing out to do the blue spring...
But then again I forgot to tighten the CAC tube clamp... You ever have that feeling when you finish a job, no left over parts you shouldn't have, no tools you've left laying in there, but still you have this feeling you forgot something as you're closing the hood?!!! At least I carry a bunch of tools with me on my post-work test drives
Old Feb 23, 2016 | 01:35 AM
Mcrafty1's Avatar
Mcrafty1
Glad this all worked out well for you.
Ford.Dude
Apr 5, 2017 12:29 PM
Irish19614x4
Jan 11, 2017 10:43 PM
Pikachu
Jul 13, 2015 03:20 PM
diesel_dan
Feb 25, 2013 04:15 PM
95PSDieselP
Apr 23, 2012 04:09 PM
