Tires
Old Feb 16, 2016 | 02:58 PM
calebheck32's Avatar
calebheck32
Tires
Hey, I have an 05 F-150, and i'm looking to put meatier tires on it. What are the biggest tires that I can fit?
Old Feb 17, 2016 | 01:08 PM
wheelerfreak's Avatar
wheelerfreak
2wd or 4wd, lifted, leveled, or stock, gear ratio? To answer that we need more info. The largest I'd run on a stock or leveled is a 33" tall tire, in my case 285/70-17. Some people have said they clear 35" tires but I use the full suspension flex on mine and there is no way a 35 would fit. Going too large will also require regearing your diffs or it will be too sluggish especially if you have the 3.55's. Even with the 3.73's in my truck, it is fairly sluggish and I plan on going to 4.56's.
Old Feb 18, 2016 | 01:07 PM
FordBoyBeau's Avatar
FordBoyBeau
My 04 has a leveling kit, when I got it, it had 35 inch bfg all terrains with 20 inch chrome rims... needless to say I got rid of all of it. It would rub a small amount when turning the full amount of traverse. I would stay closer to 33s as I think those look the best on my truck. Stock suspension, 33 is probably as big as you can go. If you're wondering tire brand for an all terrain, then be ready for the storm.
Old Aug 2, 2016 | 11:25 PM
Rickf15083's Avatar
Rickf15083
im running 40's on my 04 depend i started with 32 then 35 37 now 40 how much lift you got and how much you want to put on
case_7010
6.4L Power Stroke Diesel
Mar 26, 2009 12:40 PM
Kott3670
2004 - 2008 F150
15
Mar 2, 2009 07:28 PM
PHS79
2004 - 2008 F150
Jan 16, 2006 07:36 PM
2006HarleyF250
Dec 12, 2005 04:54 PM
TheDuke
Apr 30, 2005 06:24 PM
