Fuel, spark, no start.
Old Feb 15, 2016 | 07:12 PM
Jcampe's Avatar
Jcampe
Hello all. I have an 87 F150 with the 4.9. I'm getting fuel and spark. The fuel pumps run constantly with the key on. I know this points to a bad computer, but from what I've read on here,if its the computer, the pumps will shut off if you unplug it. I unplugged the computer and the pumps keep running. Any ideas? Thanks.
Old Feb 15, 2016 | 10:32 PM
Jcampe's Avatar
Jcampe
Anybody? I'm kind of stumped here. I don't want to replace the computer if that's not it. Any ideas on to why the pumps run with the computer unplugged?,
Old Feb 15, 2016 | 10:35 PM
Duvaren's Avatar
Duvaren
Fuel pump runs constantly? I am an amateur, but my guess would be a bad fuel pressure regulator.
Old Feb 15, 2016 | 10:37 PM
Tedster9's Avatar
Tedster9
Welcome to FTE
Sorry I can't be more help. I will say bad grounds and connections can mimic more expensive or complex problems. Always worth investigating before throwing parts at it.
Also your truck (or the computer) is at the age where some of the internal components are well past their expected lifespan. Electrolytic capacitors. These should be replaced regardless, they aren't expensive. This may be part of the issue (guessing). Hopefully somebody will be along with more than generalized advice and troubleshooting.
Ted
Old Feb 15, 2016 | 11:37 PM
Lead Head's Avatar
Lead Head
If you disconnected the main 60 pin computer connector and the fuel pump still runs with the key on, either your fuel pump relay is stuck on, or you have a fairly major wiring fault somewhere.
Old Feb 16, 2016 | 06:42 AM
Jcampe's Avatar
Jcampe
Thanks guys for all of your input. I was thinking the same thing about a wiring issue. The truck is not my daily driver so it does sit a lot. So if it doesn't shut off the pumps whatever I unplug the computer, can I eliminate that as a possibility. I have opened up the computer and there are no burn marks and everything looks pretty good.
Old Feb 16, 2016 | 07:01 AM
Tedster9's Avatar
Tedster9
Looking at capacitors isn't really a valid test. They should be replaced based upon their age alone. If they leak visibly they are obviously defective but, the reverse doesn't mean that they are OK by any stretch. And we're talking a half hour and $5 worth of new parts.
Shadetree 61
Jul 1, 2014 02:01 PM
george1016
19
Jun 28, 2011 08:45 PM
crimsonchin
May 17, 2009 04:48 PM
hondo2380
Nov 2, 2007 06:28 PM
cedarratt
Apr 18, 2004 06:33 AM
