I have a 93 f150 302 engine
I have a EZ Scan 3000 AutoXray and when I did a scan with the engine running, it shows a code 33 and says that the EGR valve is closed/erratic or has insufficient flow, I have checked and don't have any vacuum leaks, any advice would be appreciated.
Unless you actually took your intake plenum off and looked at the vacuum lines back there, i doubt you can guarantee no vacuum leaks. The plastic lines get brittle over time and can crack easily.
Try what K suggested, but don't rule out a vacuum leak yet.
I did what K said to do , I took the EGR off and used a piece of wood and tapped the plunger, it was stuck and when I tapped it it broke loose, so I cleaned it real good, re-installed it and it is working great, I did another scan and it came up with no codes this time
Thanks for the help
