Sponsored by: Real Truck
Front spring replacement Yes or No suggestions
Old Feb 14, 2016 | 02:48 PM
67camaro's Avatar
67camaro
Asking for tips and suggestions
Ok the truck is a 2001 Ford f 350 crew cab 315k 7.3 diesel 2 wheel drive
I carry about 500 to 600 load daily
I do not tow a trailer and the truck never has
I have all the replacement parts to replace 10 pcs total ...all the control arms, upper and lower ball joints, sway bars, inner and outer tie rods, inner and outer bearings, rotors
Front Shocks have about 10 months on them pro comp
Question is should I replace the front springs when I am in there
Old Feb 14, 2016 | 05:57 PM
Tom A's Avatar
Tom A
I would only replace them if they're sagging or have any broken leaves. You may get other opinions.
Old Feb 14, 2016 | 07:13 PM
67camaro's Avatar
67camaro
Front coils
I should have noted this is a 2 wheel drive
Old Feb 14, 2016 | 07:16 PM
Tom A's Avatar
Tom A
In that case, I would probably only replace them if they're sagging. But coil springs are way cheaper than leaves, so you may still want to for peace of mind.
Old Feb 14, 2016 | 07:44 PM
67camaro's Avatar
67camaro
Thanks I was looking at the Tuf Springs
They have good reviews for replacements only few hundred
Your avatar picture looks like it needs some shocks ha.
Old Feb 14, 2016 | 09:37 PM
scottz99's Avatar
scottz99
Veteran: Navy
I put F450 front coils in my F350 to cure the death wobble.
rferoni
2004 - 2008 F150
Mar 3, 2018 09:25 AM
rcknrbn
2004 - 2008 F150
Oct 12, 2014 04:39 PM
Tyler.172
Feb 20, 2014 01:04 AM
78ford351m
Jun 21, 2010 04:29 PM
asmith5rgv
1983 - 2012 Ranger & B-Series
Mar 31, 2007 04:03 PM
