1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front spring replacement Yes or No suggestions
Old 02-14-2016, 02:48 PM
67camaro's Avatar
67camaro
67camaro is offline
Asking for tips and suggestions
Ok the truck is a 2001 Ford f 350 crew cab 315k 7.3 diesel 2 wheel drive
I carry about 500 to 600 load daily
I do not tow a trailer and the truck never has
I have all the replacement parts to replace 10 pcs total ...all the control arms, upper and lower ball joints, sway bars, inner and outer tie rods, inner and outer bearings, rotors
Front Shocks have about 10 months on them pro comp
Question is should I replace the front springs when I am in there
Old 02-14-2016, 05:57 PM
Tom A's Avatar
Tom A
Tom A is offline
I would only replace them if they're sagging or have any broken leaves. You may get other opinions.
Old 02-14-2016, 07:13 PM
67camaro's Avatar
67camaro
67camaro is offline
Front coils
I should have noted this is a 2 wheel drive
Old 02-14-2016, 07:16 PM
Tom A's Avatar
Tom A
Tom A is offline
In that case, I would probably only replace them if they're sagging. But coil springs are way cheaper than leaves, so you may still want to for peace of mind.
Old 02-14-2016, 07:44 PM
67camaro's Avatar
67camaro
67camaro is offline
Thanks I was looking at the Tuf Springs
They have good reviews for replacements only few hundred
Your avatar picture looks like it needs some shocks ha.
Old 02-14-2016, 09:37 PM
scottz99's Avatar
scottz99
scottz99 is offline
I put F450 front coils in my F350 to cure the death wobble.
rferoni
2004 - 2008 F150
03-03-2018 09:25 AM
rcknrbn
2004 - 2008 F150
10-12-2014 04:39 PM
Tyler.172
02-20-2014 01:04 AM
78ford351m
06-21-2010 04:29 PM
asmith5rgv
1983 - 2012 Ranger & B-Series
03-31-2007 04:03 PM
Quick Reply: Front spring replacement Yes or No suggestions
