Coolant
Old Feb 13, 2016 | 06:34 PM
F250_6.7's Avatar
F250_6.7
Coolant
Well like I mentioned before I'm new to diesel trucks. My dash lite up today saying check coolant additive. So I popped the hood and noticed 2 reservoirs. Is one an overflow? If not do they both require the special orange motorcraft coolant? The one on the passenger side front was at the correct level. The one near driver side is low. I took the cap off and used a flashlight to get a look and it didn't look orange. It looked darker. But I stuck a rag down and it looked orange on the rag.
Old Feb 13, 2016 | 07:11 PM
superrangerman2002's Avatar
superrangerman2002
You'll need to stop by a local dealership and pick up some motor craft orange coolant for your psd. Make sure you don't buy the gold antifreeze.
Both resivoirs take the same kind. One is for the egr, the other is for the motor and tranny.
The notification is for testing the condition of the af not necessarily the quantity.
It can be done at the dealership or by yourself using test strips.
Old Feb 13, 2016 | 07:26 PM
F250_6.7's Avatar
F250_6.7
Ok I have probably half a gallon left I will add it then go get it tested. I deleted the egr about 1.5 months ago and refilled that resevoir since I lost coolant when I removed it.. I never checked the other tank until today partially cause I thought it was the same system. Thanks
Old Feb 13, 2016 | 07:31 PM
superrangerman2002
If you use the search function on this forum there is lots of info on how to do the testing your self.
Old Feb 13, 2016 | 09:38 PM
F250_6.7's Avatar
F250_6.7
I tried the search but nothing showed up. I'm also doing it off my phone so not sure if that's why. Thank you
Old Feb 14, 2016 | 04:34 AM
lynnmor's Avatar
lynnmor
You have a power steering reservoir, be sure that you aren't looking at that.
Old Feb 14, 2016 | 06:27 AM
senix's Avatar
senix
You can get your own test strips.
[328-R071-ELC ]Ford/Rotunda ANTIFREEZE COOLANT ELC CONTAMINATION KIT (Ford 6.7 diesel)
Old Feb 14, 2016 | 07:27 AM
F250_6.7's Avatar
F250_6.7
Its not the power steering resevoir. I will have to get them strips thanks guys
lynnmor
6.7L Power Stroke Diesel
Aug 17, 2015 08:27 AM
Native Tex
Jan 20, 2013 12:55 PM
Grunttorque
13
Oct 17, 2012 09:27 AM
rocdril
Nov 4, 2010 07:31 PM
eric777
Sep 28, 2009 04:56 PM
