I have been trying to search for a any topic that covers rebuilding the door hinges for these trucks. And nothing is coming up via Google or searching the forum.
Specifically I am looking for clear pictures of the hinges and how they go together.
Yes, I know there is a pin that holds the two parts together, but I would like to see both pieces of the hinge apart to understand them better.
Is there just a pin?
What size is the pin?
Are there bushings?
What size are they?
Is there a detent of some kind?
Yes, I know there are hinge repair kits available, not what I am looking for. I am on the other side of the world and cannot take my door off to investigate to see myself, so, that is where I need the help. Thank you!!
These hinges are simple they have a brass bushing top & bottom I think the pin is 1/4" it all come out easy with just a punch & small hammer. The hardest part is removing the door & replacing it. I'm sure I got the replacement pins for Dennis Carpenter. But if the hinge bushing is overly warn it may not hole the bushing. I guess it could be welded up and Redrilled. May be you can see some on ebay.
