1986 E350 exhuast headers?
Old Feb 12, 2016 | 04:50 PM
mos68x's Avatar
mos68x
Has anyone found exhaust headers that will actually fir the van? I've got the 351W but no company that I've talked to wants to say without a doubt that their headers will fit the van. Of course I would love to have long tube headers, but I know that there is no possible way that they will fit in the van. This means that the only option that I have is to get a set of shorty headers, unless someone has a better idea.
Old Feb 14, 2016 | 09:33 AM
mos68x's Avatar
mos68x
These Headmann headers are the only ones that appear to be able to fit, hopefully without an issue, but I was hoping someone else has already attempted to install some headers.
Hedman Street Headers 88650 - Free Shipping on Orders Over $99 at Summit Racing
I didn't want to spend a ton of money on headers if they didn't end up fitting, but I'd like to be able to get some performance headers for the van. Worst case scenario, I'll just get a header kit and make a set myself. I just wanted to avoid that if possible since that would take much longer to ensure that it fit properly.
Summit Racing® Header Flanges SUM-670195 - Free Shipping on Orders Over $99 at Summit Racing
Old Feb 14, 2016 | 05:48 PM
gman97005's Avatar
gman97005
Based on the reviews i would avoid them..
You've got stock heads so hedders will most likely not be worth the expense and trouble..
I don't know what your current exhaust consists of but there are major gains to be discovered just by removing the secondary cat and using a low-restriction muffler..
I see you are using a HEI distributor so setting the curve would be my next step..
curve kit with springs and weights and a pocket scale and a grinder and file along with a dial back to zero timing light, get er done..
http://www.superchevy.com/how-to/97438/
Old Feb 14, 2016 | 11:19 PM
vettex2's Avatar
vettex2
If you have a stock cam , headers won't gain you much.
Short tubes are rarely better than manifolds.
Long tubes run into smog cert issues (if applicable)
kountzecobra
Jan 18, 2014 07:42 AM
TX460Bronco
Apr 29, 2007 04:52 PM
hsfbfan
Exhaust Systems
Jul 26, 2004 08:14 AM
1974FORD-VAN
Oct 21, 2003 07:21 PM
Greg
Bronco II
Sep 29, 2001 08:47 PM
